Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Skip White Heads BBC
  #139 (permalink)
Old 06-04-2019, 08:18 AM
55 Tony's Avatar
55 Tony 55 Tony is offline
The Holley btw is a 6211 spread bore, and now that I think of it, something is wrong with the secondaries because I had 99 jets and it was still lean at WOT. I forget what I tried on it but didn't fix it. Now I do recall checking the air bleeds but didn't find a problem. It had worked for me but something seemed to happen sitting on the shelf.
The tires are 28's and that's what I have in my summit wish list, but different tires, m/t instead of Hoosiers. They take more air and are supposed to be better handling at higher speeds. Also supposed to be a compound that is better for no-prep. The m/t's get a little wild down at the far end. I had looked into smaller tires but don't think they have what I want any smaller.
On launch I've tried all different rpm's without much difference, no worry about the q-jet bogging. Shift at 6K, finish line rpm I don't know but I'm in third.
Young enough to learn ... too old to remember.
