Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Skip White Heads BBC
  #140 (permalink)
Old 06-04-2019, 08:37 AM
55 Tony's Avatar
55 Tony 55 Tony is online now
Is it true that with higher compression ratio's you can run bigger heads and bigger cams? That is the one thing Skip kept saying that my compression ratio is too low. Although it's 9.8 according to the Wallace racing calculator, and my cam says at least 9.5, stall 2800, range 2500 to 6200. I could up the shift point again, I guess if it didn't fly apart yet then it should hold up.
Young enough to learn ... too old to remember.
