Smallest diameter SBC long water pump pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2019, 06:04 PM
64nailhead's Avatar
As the title indicates, I'm looking for a small water pump pulley. I currently have a 5.5" pulley, but would be better suited with a smaller pulley.
Thanks in advance - Jim
Old 04-22-2019, 12:41 PM
Might fit might not. Call them .
https://pitstopusa.com/i-5073189-jon...xoCHQUQAvD_BwE
If your running reverse rotation there are several smooth 4" ones out which you can modify.
The Following User Says Thank You to cerial For This Useful Post:
64nailhead (04-22-2019)
Old 04-22-2019, 01:45 PM
64nailhead's Avatar
Should've menetioned that it's a double v-belt.
Old 04-22-2019, 04:52 PM
ericnova72's Avatar
More for Less Racer
The 5.5" you've currently got is the smallest I've personally found....and I've not even seen an aftermarket aluminum V-belt pulley that small, they are always larger than that.
My guess would be you are probably looking at custom making one, as most racing set-ups go larger on the pump and smaller on the crank to slow them down .
What reason are you looking to get a smaller pump pulley than the current one??
Old 05-02-2019, 05:51 PM
64nailhead's Avatar
Trying to spin the water pump faster at idle. But I guess I'm going to have to go with a larger crank pulley. Presently I have a custom made 5.5" crank pulley woth a 36-1 trigger wheel mounted on it. I was trying to re-use that, but I guess a larger crank pulley and putting another trigger wheel on it will be the plan.
Old 05-02-2019, 05:59 PM
36 sedan's Avatar
Why not use a higher flow water pump that won't caviitate.
Old 05-03-2019, 02:07 AM
64nailhead's Avatar
I'm using a Stewart Stage 2 presently. And it works very well at highway speeds and at full load. I was considering running an electric pump until I spoke to the tech people at Mezierre and they recommended against it.
I've researched different pumps, but I have no real experience. Every manufacturer claims theirs is better than the rest.
Tell me what's 'higher flow' than what I have?
Old 05-03-2019, 07:17 AM
johnsongrass1's Avatar
Race it, Don't rice it!
What are we working on and what is the issue you want to change?
Old 05-03-2019, 03:27 PM
64nailhead's Avatar
More flow at idle (below 900 rpm's) - using a 5.5. crank and water pump pulley. Triple pass radiator, remote t-stat housing fed by #12 lines.World Motown LS.
Old 05-03-2019, 03:47 PM
ericnova72's Avatar
More for Less Racer
You've got 5.5" water pump AND same diameter crank pulley??
All the factory stuff I've ever seen with the 5.5" waterpump pulley has at least a 7" crank pulley on it.
You fighting temp creep up at idle....or trying to cool it down faster/fighting slow return to cool after coming back from a WOT blast or highway cruise??
2 -12AN lines seems small to me, wouldn't a pair of -16AN or -20AN be sized more appropriate for the volume load?? You got to get the water into the radiator to get it cooled.
Old 05-03-2019, 07:33 PM
64nailhead's Avatar
Yes and yes
Low RPM / idle creep only. Cools GREAT on WOT pulls and highway driving
#12 is what the T-stat housing inlets are. Putting in larger hoses to have them restricted at the housing seems not fruitful.
Old 05-03-2019, 09:52 PM
ericnova72's Avatar
More for Less Racer
Yeah, that info helps a lot. If it cools fine out on the highway it isn't a volume/line size to the radiator problem.
Have you tried an experiment of removing the hood, to see if it is a trapped air/stagnant air problem, when there is no forward motion forcing air in through the bay??
I'm usually fighting the opposite problem with naturally aspirated street/strip cars....the common factory pulley ratio's spin the pump too fast when you add the deeper gears the street/strip guys use. We have to slow the pump down to either keep the belts on or prevent cavitation.
Old 05-04-2019, 02:21 PM
64nailhead's Avatar
Thanks for the input. I see that I can get a 6.5-6.625 pulley. I'm going with it. Figuring that it's about 20% more circumference and raising the rpms from 800-950 resolves the issue. I've thought about this too much lol - thanks for the advice everyone.
Eric - I sent you a PM - I'm on living on main bearing Struggle St for some reason - looking for some input
Chevy water pump, long and short of it. suprstock Hotrodding Basics 14 06-22-2015 07:58 AM
Belt tensioner for long water pump? HeavyChevyDeluxe Engine 6 10-22-2013 01:06 PM
Shaft diameter on chevy water pump? staleg Engine 4 11-02-2012 06:58 AM
Pulley Change Out Long to Short Water Pump Mule Engine 7 05-25-2007 07:06 AM
Shimming pulleys out to match water pump pulley 406chevelle Engine 8 07-02-2004 09:36 PM
