So I screwed up and used the wrong activator - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 01-15-2019, 06:59 AM
So I'm in the middle of blocking the car out, and ran out of primer. Sent my wife back to the body supply place to get more primer. I've been using 5 star extreme primer/surfacer/sealer, direct to metal. Anyway, they gave her 5 star extreme max build primer. I didn't realize and used the activator for the other stuff. I had already shot 1/2 gallon of it before I realized, and the activator for this other stuff is a different part number. First thing I noticed sanding is that it clogs 320 paper. I had to wet sand it. It doesn't feel soft though. So what do I do? Thanks!
Old 01-15-2019, 07:33 AM
55 Tony's Avatar
How long had it been and how long was it suppose to take to cure? How about temperature also?
Old 01-15-2019, 08:42 AM
It's been on for 3 days. I just took acetone on a rag and it comes off. Temps have been in the 70's
Old 01-15-2019, 08:51 AM
dwighty390's Avatar
The 2 activators have some pretty different ingredients in them. If they were just some slightly different ratios of a couple things, I probably wouldn't be concerned so long as it seemed to dry out and act proper.
I am going to make an assumption that you are using 5 start products to be extra cautious about budget, and now you have a tough decision to make.
Honestly, I'd get what I could sanded off and put a couple coats back on with the proper activator. If it causes issues with the basecoat/topcoat, you will only be that much deeper in.
The Following User Says Thank You to dwighty390 For This Useful Post:
Hipster_G (01-15-2019)
Old 02-22-2019, 01:53 AM
Honestly, I'd get what I could sanded off and put a couple coats back on with the proper activator. If it causes issues with the https://bestpricefinds.com you will only be that much deeper in.
How did it go?
Old 02-22-2019, 06:46 AM
Molon Labe's Avatar
Last journal entry: Floors
Modern paints are very complex chemically and few people really understand how they all react. Not to disparage anyone's feedback on this subject, but, before spending anymore time and money on this project I'd go straight to the manufacturer's tech staff and discuss it with them. I took advice from a guy who owned a body shop for forty years and it totally screwed up my last paint job. Any technical questions I have now goes straight to the experts.
Old 02-22-2019, 07:00 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Very good and correct advice given....
Pep
Old 02-22-2019, 09:31 AM
Yep, I have screamed it from the roof tops FOLLOW THE TECH SHEET. And you can't for some reason, call the tech line! I was a paint rep, and believe me, they have heard it all, don't be embarrassed, you don't need to be a pro to call them and BELIEVE ME, pros make the same mistakes!
The Following User Says Thank You to MARTINSR For This Useful Post:
cerial (02-22-2019)
Old 02-22-2019, 10:23 AM
dwighty390's Avatar
Originally Posted by tangerine View Post
How did it go?
Not sure why I got quoted or where that hyperlink came from, but you might want to quote the OP to get a response.
Stripped throttle plate screws and messed up drilling, how screwed am I? Paul_Puhmann Engine 9 02-01-2018 03:02 PM
Using slow reducer and activator in cold weather? JohnnyK81 Body - Exterior 27 09-24-2011 04:00 PM
Got screwed.. possibly still being screwed kc8oye Engine 16 11-10-2010 12:12 PM
so screwed up mustangman1968 Hotrodders' Lounge 13 02-26-2004 10:58 AM
What is the difference between activator and hardener? unioncreek Body - Exterior 1 01-29-2004 10:59 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
