some physics - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2005, 04:03 PM
Last journal entry: The Trucks Redemption
some physics
what would be the formula to figure out how much ft lbs it would take to open a car hood?
Old 01-03-2005, 05:08 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Weigh the hood anywhere on its length with a bathroom scale, at the front radiator shroud is probably most convenient. Now measure the distance from the center of the scale to the hinge point of the hood. Multiply the distance in feet times the weight in pounds and you have the moment you want. To be safe, weigh the hood with the springs (if it has springs) removed.
Old 01-03-2005, 11:07 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
Should we even ask why you would need to know??
Old 01-03-2005, 11:43 PM
lol
im just figuring out how big a acuator i should get for spliting the hood
Old 03-24-2011, 04:04 AM
Ignologist's Avatar
Really simple. attach a half inch square hole in a metal bracket to the heading edge of the hood, maybe at the hood latch. Insert a ft lbs torque wench into the square hole and lift the hood using the wrench. Start off low and increase the value until one may lift the hood without the tool clicking.
Good luck.
