Spongey brake pedal, kind of tried bleeding brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2018, 10:48 PM
A little while back, I noticed that out of now where my brakes lost most of their efficiency, i had to pump them 2-3 times to stop in a reasonable distance. I checked the fluid and it was a little low in the back, larger part of the master cylinder. The vehicle is a 1974 gran torino 4dr with discs in the front and drums in the back. I refilled the fluid, no change. I found that some fluid was leaking out the master cylinder lid seal, after fixing that and having no change in the brakes, I tried to bleed the brakes. Starting in the back, the bleeder screws on both sides were stuck. I got the passenger side and impatiently bled that drum. I couldnt get the driver side drum and I didnt have time to buy a new wheel cylinder so I moved on. I went on to the front brakes and bled out a lot of air on both sides. I didnt expect to have the brakes back fully, but there was no change at all in performance. I expected some change. I still have to pump the bakes 2-3 times. Someone please tell me if buying a new wheel cylinder and re-bleeding the brakes might fix this, or could there be something else. Why could this have happened out of nowhere?
Old 02-26-2018, 07:18 AM
delawarebill's Avatar
brakes
spongy bks tend to be air. u may have a m/c issue and don't know it yet. but for me... jack it up all around and hit brake while someone tries to spin tire and see what happens. wheel cyl's are cheap. and look at the flex brake lines for expanding too while u hit brake.
Old 02-26-2018, 08:52 AM
39 master's Avatar
spongey
Time to replace some brake parts. I see on Rock Auto a M/C is under $30 and a wheel cylinder is under $5. Look for any indication of leaking on the front part of the braking system.
Old 02-26-2018, 01:54 PM
36 sedan's Avatar
Have you tried adjusting the rear drum brakes? The self adjusters do not always keep up. Check the shoes they maybe worn out.
bleed brakes, brakes, gran torino, pump brakes, spongey brakes
Bleeding disc brakes with stuck bleeding screw wave1957 Suspension - Brakes - Steering 22 06-01-2017 08:46 PM
Brake Pedal stops have way when applying the brakes Baconboy427 Suspension - Brakes - Steering 4 10-12-2014 11:29 AM
Low brake pedal in Volvo with 4 wheel disc brakes Torque454 Suspension - Brakes - Steering 0 06-23-2014 03:21 AM
soft brake pedal poor brakes 62restomod Suspension - Brakes - Steering 6 04-16-2014 10:57 AM
brake pedal hard then soft but hardly any brakes Wildwestshow Suspension - Brakes - Steering 1 12-24-2010 08:18 PM
