St400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2019, 03:38 PM
St400
I'm running a ST400 behind a nailhead 401 in 34' ford. There is a 1/4" cup plug with a .040 hole in it that restricts the oil for the pitch control. It gets clogged every once in a while. Has anyone had this problem? Could I enlarge the hole to .060 or .080 without problems? I have made all the usual 400 mods, dual feed to direct clutch's, separator plate holes, etc
Old 08-28-2019, 08:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the oil feed is metered down so the solenoid on the back of the pump can function for switch pitch. With a large hole feeding.. the circuit can be flooded and the switch pitch may not activate correctly.
I would determine why the hole is becomeing clogged.
If you open the hole up , keep that size increase to less than 33% ....
Old 09-08-2019, 01:47 PM
Thanks Crosley
Thanks for the info Crosley. I'm going to pull the trans out tomorrow. I know solenoid is working and it's getting voltage etc. I bought a rebuilt converter from Florida Torque Converter but have yet to get this thing working correctly. I'm begging to think I may have a bad converter. This the last time i'm going to mess with it. Don't want to do it but if it doesn't work this time I have 700 I put in. Much trouble to do but might be worth it.
