Starting the old hemi tomorrow. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2019, 08:11 PM
5 years of work and starting it up tomorrow. wish me luck
Old 07-12-2019, 08:23 PM
forgot picture
The Following User Says Thank You to Cutitup55 For This Useful Post:
John long (07-13-2019)
Old 07-13-2019, 03:11 AM
Luck wished for!
John
Need more pictures too.
Old 07-13-2019, 04:31 AM
A bunch of luck.
More pictures please.
Old 07-13-2019, 06:27 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
Nice looking motor, best of luck with the start-up. Hopefully, you won't be reading this until later on today or tonight, because right now you're listening to a great sounding motor. Let everyone know how you make out.
Old 07-13-2019, 06:55 AM
Good morning. Having my coffee before I head out and fire up the 392 in my 57 coronet. Been at it 5 years and still a ways from driving it . It was a pretty much untouched stock coronet when I bought it but the 325 poly motor was junk and so was the drive train. Had to fabricate new floors and inner and outer rockers as well as the trunk floor. The rest of the body though is very solid. I installed a front suspension from a 93 dodge dakota and a 8.8 ford differential from a mustang gt. Had to fabricate the headers. The 392 is pretty much stock with a mild cam and holly sniper injection. It has a 700r4 trans and rides on 7" air bags in front and bags over the leaf springs in the rear. Not going to do anything to the body. Plan on this being my daily driver and pulling the wife"s vintage travel trailer with it. Had to build this car in my driveway as my 2 car garage is filled with tools and my 59 ramler american.
Well, time to head outside and get it ready to fire up. It's already in the 90's outside here in the phoenix valley area and it's not even 6 am yet. Should be to running temperature in seconds
Have a great Saturday.
Ed.
ID:	445031   Click image for larger version
ID:	445033   Click image for larger version
whinny (07-14-2019)
Old 07-13-2019, 07:38 AM
RWENUTS's Avatar
Nice project!
I had a 58 moredoor. Was pink/black.
Must be interesting breaking in a motor set up like that.
I would assume flat tappet cam so how do you set the rpm higher with that injector on there?
Old 07-13-2019, 02:59 PM
WABOOM's Avatar
How did break in go? 2000 rpms for 20 minutes?
Old 07-13-2019, 06:24 PM
Everything went alright. Didn't make 20 minutes, it started to get a bit warm. Ran it again this afternoon and it seemed better.The factory temp gauge shows it running hot but when I check the temp at the sender with a heat gun it was about 190. It ran a bit rough at first and then smoothed out.
This is my first experience with self tune injection so maybe that's normal. It shouldn't run hot at all, the radiator is more than large enough and the electric fans pull tons of air. It has a 160 thermostat and I would like to see temps lower but it is also very hot here today, 109 degrees.
Old 07-13-2019, 07:22 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Running a 160 thermostat is a rookie mistake. Replace it with a 190/195.
The Following User Says Thank You to techinspector1 For This Useful Post:
RWENUTS (07-14-2019)
Old 07-14-2019, 06:17 AM
Please explain why the 160 thermostat is a mistake.
thanks
