Starting a T build. Putting the horse before the cart. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 06-09-2018, 07:18 PM
Bamamav's Avatar
I bleed FORD blue!
I don't think I would try to run a IRS Jag with a I beam or tube axle front. Although it was done it the 70's, I don't think it would handle too good. A Ford 9" or 8.8" would be a better choice IMHO. IFS and IRS look funky on fenderless cars.
  #17 (permalink)
Old 06-09-2018, 07:20 PM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
jag irs
search T bucket plans CCR has chassis plans including prints to install a Jag IRS The Jag uses a Salsberry gearset, euro version of a dana 44 there is info on how to use US dana 44 parts. We put a XJ6 irs in my son's 22 Dodge lakester. If you are serious I have a lot of info on how to and how not to,
The Following User Says Thank You to timothale For This Useful Post:
Mykk (06-10-2018)
  #18 (permalink)
Old 06-09-2018, 07:25 PM
Wiki Edits: 27
Jag ifs
k&k custom crossmembers in Australia do the Jag pieces in their IFS BUT they haven't answered my E mails.
  #19 (permalink)
Old 06-10-2018, 06:30 AM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Interesting build I'll be watching as it goes...
pep
  #20 (permalink)
Old 06-10-2018, 06:37 AM
I am serious about the jag rear, I mean... c'mon how cool is this?!
  #21 (permalink)
Old 06-10-2018, 06:42 AM
Still putting the "horse" together. Modified the supercharger to bolt down on the adapters. Re-timed the cams for a more boost friendly 110 ICL & 112 LSA.
  #22 (permalink)
Old 06-16-2018, 07:05 PM
  #23 (permalink)
Old 06-30-2018, 06:51 AM
Nitrous...'cause why not.
The Following User Says Thank You to Mykk For This Useful Post:
fiftyv8 (07-28-2018)
  #24 (permalink)
Old 07-13-2018, 05:13 AM
Started fishing the transmission & driveline from the donor car. Going to utilize as many pieces as I can from the mid 90's BMW.
I don't think I can use much but even having the transmission, clutch and driveshaft I feel like I've got most of the T-bucket project already...minus the T.
  #25 (permalink)
Old 07-13-2018, 09:29 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Grab lots of bits and pieces like harness and other parts for the parts bin. All the little pieces mount up. Ask me how I know..
Sam
  #26 (permalink)
Old 07-28-2018, 07:44 PM
Jag rear end acquired, can anyone help with ID? rough measurement from hub to hub is 60"
  #27 (permalink)
Old 07-28-2018, 08:48 PM
fiftyv8's Avatar
ID:	433473I like your choice of using the Jag IRS in your build.
They are capable of handling quite a lot of HP.
I have attached several pages of a document that will help ID your diff.
There are numerous little changes that were mad to these rear ends over the life time of them being produced.
Being that you seem to be keen to do things right, may I suggest that you consider the following modification to your Jag diff build.
I will attach in my next post the last page of the current ID pages and a pic of such a modified diff.
The mod is to use the outer hubs and brakes of a later model Jag, I believe the model is called an XJ40.
This mod offer you clear space for your exhaust to pass thru as the disc brake rotors are removed to the outer hub.
It also offers you a much better park brake arrangement.
All you do is machine up a spacer in say aluminum the thickness of the disc brake flange that you are removing.
The only other mod is a slight amount of reaming to adapt the older hub shaft and bearings to the new XJ40 hub.
May I suggest that while I like the engine you are using and the frame you have chosen, but I feel a lot of your effort maybe wasted putting it into a T bucket body.
They look great and turn heads but....
Your call, but I see other T choices as more functional and since this looks to be a build that has a great capacity to be driven any where, comfort comes to mind.
I feel you could be investing your time and money into a body that will provide you with a greater capacity to recover your costs and be more drivable all year round.
Just my 2 cents worth and take it as just another opinion to consider.
Keep up the good work.
  #28 (permalink)
Old 07-28-2018, 08:58 PM
fiftyv8's Avatar
AS PROMISED HERE IS THE LAST PAGE AND PIC OF THE MODIFED JAG IRS I MENTIONED.
There are two main styles of rear cross member to mount the diff as shown in the attached pic's
Generally for a Model T the single center over the top style would be commonly used.
ID:	433475   Click image for larger version
ID:	433477   Click image for larger version
ID:	433479   Click image for larger version
ID:	433481   Click image for larger version
The Following User Says Thank You to fiftyv8 For This Useful Post:
timothale (07-29-2018)
  #29 (permalink)
Old 07-28-2018, 10:23 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Great info, thanks.
The Following User Says Thank You to techinspector1 For This Useful Post:
  #30 (permalink)
Old 07-29-2018, 06:46 AM
fiftyv8, thank you dearly for the time and resources posted above. That is some great info.
383 build horse power cam? peteall70chevy Engine 0 02-23-2011 11:10 AM
Big Block Chevy Horse Power Build d^2 Engine 14 12-29-2010 08:53 AM
327 build horse power guestimation inbredjedd Hotrodding Basics 2 07-11-2009 07:01 AM
Cart before the horse? 428ho Body - Exterior 9 08-25-2006 09:51 PM
Want to build 500 horse chev 454 79monte Engine 6 05-29-2002 09:20 PM
