Steel braided PTFE hose on barb end ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2019, 02:00 PM
staleg's Avatar
Last journal entry: Hand brake
Hi
Is it ok to fasten a steel braided PTFE fuel hose to a barb fitting end with a standard hose clamp?
It's a low pressure carb fuel system.
I know it won't be a very nice connection, but will it work ok?
I'm about to change out all my steel braided fuel hoses with PTFE ones, and have barb fitting ends a couple of places.
I'know I must change the other fittings.
Old 03-14-2019, 08:31 PM
It is not recommended. The barb wont squeeze the ptfe enough.
I recommend you use a "push to connect" barb fittings with Gates "Bariccade" hose.
I love this stuff and it is not much more expensive then low pressure line.
Using the push to connect fittings you wont need any clamps and using the barricade line your system will be good to run any fuel through the lines and move up to high pressures later.
https://www.gates.com/us/en/fluid-po...0014/v/1111089
Most places have the line for $5-7 a foot.
I recommend you use hard line with flared ends where ever possible and for bends with any section of hose saved for straight pieces connecting the lines or line to tank/filter,/pump/pump/carb.
This cuts down on the cost of your "soft" line while lessening possible leaks.
For hard line break line works good. You can use "green" line but it rust quickly.
Nicopp line last longer and is easy to bend/flare.
https://www.amazon.com/Nickel-Copper.../dp/B00A1WBYUC
A $25 harbor freight flare tool will let you double flare the ends to slide the hose over the greased nicopp before adding 2 offset clps.
For high pressure systems you can use break fittings on the flared end with a coupler to connect push to connect barb fittings eliminating most of the soft lines completely. The nicopp flexes enough to allow for chassis flex and can be held tight to the rail with clamps.
https://www.amazon.com/Clamp-20-Insu.../dp/B07CJRVB3Y
If your bringing this to the track follow there rules.
The Following User Says Thank You to cerial For This Useful Post:
staleg (03-15-2019)
Old 03-15-2019, 03:59 AM
staleg's Avatar
Ok, thanks!
Old 03-20-2019, 07:13 PM
You can just go back to the quick connect fitting connecting one like in the link below.
Then screw on a push to connect an6 or 8 barb fitting to slide fuel injection hose over that barb. Run that hose to a flared hard line or all the way to your post pump filter/tank return.
https://www.summitracing.com/parts/r...RoC_ZsQAvD_BwE
Throw a caliper on your male quick disconnect tube for size and check to see if your rail has a diffrent locking style then the GM style one in the above link.
Old 06-15-2019, 08:23 AM
predator carb guru's Avatar
Mark Goulette
PTFE is great stuff but you must use either reusable or crimped AN fittings. For street applications, regular braided line is just fine, and you can run the whole system with it. Steel lines where no flex will occur is better, but you'll need to have a good tool to flare with, and good flares take practice. You CAN run aluminum fuel line, but it's going to be subject to vibration and work hardening, which will cause it to crack. DO NOT USE BRAKE (not "break") lines for fuel, especially if using fuels that contain a percentage of alcohol. The solvents in the fuel can break down the plating in the lines and cause issues with the fuel system. If you plan to use steel hard lines, get plain tubing. If you want to spend the coin, stainless is a great option but expensive, hard to bend, and even harder to flare as you can only do single flares or it will split. Regardless of which direction you go, take your time and have fun with it!
The Following User Says Thank You to predator carb guru For This Useful Post:
staleg (06-26-2019)
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
55 front end....yep monkey hair or steel? DeathByGreaser Body - Exterior 2 09-04-2003 12:15 PM
all steel front end tilt kit info. old c10 head Body - Exterior 14 05-03-2003 09:59 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 02:45 PM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 11:50 PM
