Steel Cutting Lube - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2018, 07:35 PM
thinwhiteduke's Avatar
Living In The Past
Steel Cutting Lube
I’m drilling a lot of holes into metal (mild steel)
I have premium quality drill bits and are using lubricant (Suttons Metal Cutting Lubricant) , works a treat, but was wondering if there was a cheaper option than this expensive oil.
Any of you guys have an alternative?.... Is engine oil or ATF going to provide equivalent lubrication and cooling?....As a metalwork student in high school, i recall we used to make up what was called ‘soluble oil’ which was simply oil and water mixed.
Anyone got a new age formula for an inexpensive lubricant/coolant for cutting/drilling mild steel?
Thanks guys ✌️
Duke
Old 09-13-2018, 11:38 PM
Here you go Duke. I get it from Amazon. $15 bucks. Works great.
BB
Sta-Lube SL2512 Soluble Oil, 32 Fl Oz
Old 09-14-2018, 11:08 AM
https://www.homedepot.com/s/thread%2...2520oil?NCNI-5
Click on above. Thread cutting oil. That's what I use.
Old 09-14-2018, 08:48 PM
Living In The Past
Thanks guys
Old 09-14-2018, 09:34 PM
rip-tide's Avatar
Magazines have “ISSUES”
Last journal entry: Looks good
Check your speed, too fast, too much force will dull a bit real quick. Let the bit do the work...
BTW: what's expensive, meaning price ?
Pep
Old 09-15-2018, 11:19 AM
I use marvels mystery oil for cutting, drilling, in the air tools, in my oil, and in my fuel.
Stuff is cheap enough and I always keep a bottle in the shop or have one in something I drive.
Old 10-11-2018, 12:30 PM
PHWOARchild's Avatar
Marvel works well, I've used WD40 on aluminum. I have a buddy who owns a big machine shop and he lets me take a few bottles of water soluble coolant home, the mix is 50:1 so a little lasts me years.
Old 10-13-2018, 02:14 AM
https://en.wikipedia.org/wiki/Cutting_fluid may be helpful here...
https://www.amazon.com/Ounce-Bottle-...dp/B002R7VMEW/ is good for many metals such as aluminum, stainless steel etc...
Old 10-13-2018, 08:21 AM
rip-tide's Avatar
Because it's so great or you don't cut much?
There are many good brands of cutting oil. I used the ACE hardware brand for hack saw and drilling.
After purchasing machines, now use Tap Magic. Cutting, drilling and taping, as mentioned WD is good for aluminum .
Metal bandsaws use a stick type lube, oil and rubber drive tires not a good combo.
Cutting oil, like motor oil a users choice and how much is it worth to the same.
Yes I have my preferences one size does not fit all. Because the different materials used for the tooling is also in play.
But without a doubt using cutting oil is the right way to go.
Pep
Old 10-13-2018, 11:59 AM
Living In The Past
Pep
Thanks for the ongoing replies, the wiki article was interesting.
The last bottle in bought was Sutton’s brand and was A$16.98 for 250ml bottle/ US$12 for 8oz, give or take
Obviously the small bottle is not a cost effective way to purchase.
I’m in Oz so some of the products mentioned are not necessarily available here and we have other ones.
I was wondering if someone had homemade recipe they found worked well.
Duke
Old 10-13-2018, 06:16 PM
This is what I use. https://www.acehardware.com/departme...CABEgKszfD_BwE
I am not kidding you, if this friggin can were to cost $50, I would buy it, THAT is how good this stuff works. I am not comparing it with others understand, I am not saying it's better than some other product. All I am saying is it's MIND BLOWING better than not using it! I use it with the hand hack saw, air saw, drills, and of course tapping, it's awesome stuff!
Old 10-15-2018, 11:49 AM
Brian,
I think the previous formulation was a bit better; but its still great stuff.
The Following User Says Thank You to AutoGear For This Useful Post:
MARTINSR (10-16-2018)
Old 10-18-2018, 08:46 AM
Pep
A 1/2 gallon of water soluble makes 25 gallons of coolant... that is a lot for my use.
I have a can of Tap Magic, works well. I also have Anchor Lube which can be thinned down, also Moly Dee for tapping harder materials.
My Bridgeport and lathe are set up with coolant pumps, I use the spray mist on the mill now and then.
Cutting sheet steel tip MARTINSR Hotrodding Basics 3 01-19-2015 11:56 AM
Thread cutting oil for stainless steel? 5window General Rodding Tech 8 01-07-2014 05:43 PM
Cutting steel boothboy Hotrodding Basics 2 06-15-2012 08:22 AM
steel cutting lrich Garage - Tools 1 11-01-2006 03:23 AM
cutting stainless steel bct General Rodding Tech 7 02-17-2004 06:15 PM
