Steering: Pinto spindles, Granada rotor questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2019, 08:55 AM
I have a 46 Chevy pickup and I used a cross member out of a pinto,and used Granada rotors so I bought backing plates from a 75-79 Granada but they don't bolt up to my pinto spindles.So I was wondering if I bought Granada spindles will my Pinto rack bolt up to the spindles or what do I have to change for the swap thanks
Old 01-28-2019, 03:28 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Welcome Richard. I hope someone comes along with some help soon.
454 RATTLER
Old 01-28-2019, 04:26 AM
dusterdude3404's Avatar
Im assuming you're concerned about the tie rod ends?you can go to moogs website and look at both ends and see if the taper and the thread size on the rack end is the same.
Sent from my LG-US601 using Tapatalk
The Following User Says Thank You to dusterdude3404 For This Useful Post:
Richard Adams (02-18-2019)
Old 02-01-2019, 09:24 AM
This won't work. Pinto spindles are front steer, and Granada spindles are rear steer. If you managed to get it bolted together the Ackerman angles are totally wrong, and you will have tons of tire scrub. In addition the steering arms are much longer and will increase the turning radius greatly.
There are tons of adapters made to use a GM caliper with your Granada rotors on the Pinto spindle. But to use Granada calipers you are on your own. I would just use GM calipers instead of reinventing the wheel.
The Following User Says Thank You to enjenjo For This Useful Post:
Lower control arm hits Granada rotor on stock Mus II suspension Darkman270 Suspension - Brakes - Steering 8 07-25-2006 01:26 PM
Ranger / Pinto rotor swap mr.Pinto Suspension - Brakes - Steering 1 07-26-2004 11:20 PM
dropped spindles and granada brakes? flamedfordbronco Suspension - Brakes - Steering 13 02-20-2004 06:06 PM
Will ford 14" rallys fit granada spindles FAIRLANE DUDE Suspension - Brakes - Steering 1 10-07-2003 09:23 PM
granada spindles on Mustang II IFS ??? deuce_454 Suspension - Brakes - Steering 11 03-24-2003 04:13 AM
