Steering problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2015, 12:47 PM
The Belgian's Avatar
Steering problem
Hi guys!
I recently purchased a 1959 chevy 3100.
it would run and drive great except for one thing, the steering.
i added a few pics to explain the problem. any normal car would steer at the angles explained by the red lines. wich is pretty logic because the inner wheel makes a smaller circle than the outer wheel.
My car has it just the other way. the outer wheel makes a smaller circle than the inner wheel. as shown in the other picture with the green lines.
wich makes the outer wheel skip and bounce when taking a turn. and because they're brand new white walls i don't want to destroy the tires, so i haven't been driving since. not that long though.
edit: i've purchased the car like this.
I've inspected the steering and everything looks okay, i've got no clue what to do next. i've been thinking that the rods are not in the right place or something. i've found a shop manual that tells me it's possible to mount it the wrong way, but i can't see something fitted wrong because that looks impossible.
maybe someone had this issue before, hope you can help me out.
thanks,
The Belgian
ID:	226641   Click image for larger version
Name:	steering-turning 2 copy.jpg
Old 06-14-2015, 01:58 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
A bent steering arm might be a culprit.. First thing to check is the wheelbase the same on both sides. then check to see that the axles are square to the centerline of the truck. I do that by scribing a center line on my garage floor and making two lines one at the rear end and one at the front end and dropping a plumb bob from the axles down so I can see whats going on. If all that checks then I go to alignment. Camber on those is fixed so then I go to the toe in and check that. Should be about an 1/8 inch. I also check castor to see if anything is off there. Looks to me like you may have a bent steering arm or the spindles were replaced with some from another truck at some time.
Just my guess.
Sam
Old 06-14-2015, 02:28 PM
well it's a 2wd and the steering arms are straight. nothing seems wrong by taking a look at the steering mechanism. going straight forward it drives great, camber is good (by my experience and logical thinking) strange thing is that it's in both ways. going to the right and going to the left, the wheels are doing the opposite of what's right, as explained in the pictures. it looks like the entire front axle was demounted and fitted on again completely backwards. so if i could take it out, spin it 180 degrees and put it back in, it would be working normal. but then the steering wheel connection would be at the wrong side.
also the rear axle has nothing to do with it, because it's clearly visible by just turning the steering wheel and without driving.
rear seems fine and i cant see significant damage ever occured on the frame. frame looks old but in decent condition. so the crab walk doesn't occur on this car.
i'll try to take some pictures later this week.
Old 06-14-2015, 05:39 PM
Does this by chance have a rack and pinion conversion on a front end that originally had a steering box? I have seen this in the past when a rack is mounted too close to the centerline of the axle, and the tie rods actually go forward to the steering arms on the spindle. Any idea what type of front end you have?
Old 06-15-2015, 06:03 AM
delawarebill's Avatar
orig steering box ????
if so, ck the steering arms located on the spindles. is one longer then the other ???
Old 06-15-2015, 08:05 AM
Are the steering arms on the spindles facing forward or backward? If it was swapped around for some reason, the ackerman angle (which is what you are talking about ) would wrong as you have described. There is nothing else that can cause this but the spindles being on the wrong side with the steering arms facing forward, period, there is nothing else that can do this.
If one side were being bad or something like that, it would make this happen turning one way and then turning it the opposite way would simply make the inside wheel turn too much but to make it turn too little turning it both ways could only be caused by the spindles being on the wrong sides with the steering arm off the spindle facing forward.
They probably swapped the axle around so the tie rod went in front to clear the oil pan on the motor they swapped in. Or as mentioned, does it have rack and pinion? And they swapped it around to so the rack was out front as to not get in the way of the oil pan.
Can you shoot some photos?
The Following User Says Thank You to MARTINSR For This Useful Post:
LATECH (09-07-2015)
Old 06-15-2015, 08:25 AM
1971BB427's Avatar
Before all the what is wrong answers, it might help knowing if this still has the stock straight axle, or if it's had a front suspension swap done? And if it's been changed, then what did they swap into the truck?
Old 06-15-2015, 09:34 AM
Exactly, it could be because it's mounted on a '62 VW Bug pan with the engine in front and the steering in the back! We ARE just guessing for goodness sakes!
Post some photos so we know what the heck you have.
Old 06-15-2015, 12:36 PM
and quote to all the others.
that's exactly what's going trough my mind the last day. i don't have any experience on old chevy's so i can't tell if it's the stock steering setup. my good friend google gave me alot of pictures but none of them looked familiar. i've only found a 55 shop manual so i can't say if it's the same or not.
my guess is the best thing to do is to take a few pictures, wich i will do one of the days, because the car is at a friend's so i need to be sure he's home or i can get in
i might have been a litlle cheap on details but it's not a power steering, and i've noticed that the steering rod that connects the steering wheel to the steering axle (or what you call it in english) has been modified. it looks like it's made out of two parts that were welded togheter. you'll see it in the pictures coming soon.
i'll keep you updated!
and a big thanks in advance!
The Belgian
Old 06-15-2015, 12:52 PM
The Belgian
It is really sounding like the axle is swapped around with the steering arms out front. All the evidence is leading that way.
Old 06-15-2015, 01:09 PM
Make sure that the Idler Arm is not reversed. This can happen if the vehicle's front tire struck a obstacle while backing up. This can set the front end up like you have shown. Ask how I know. I have a 1970 Chevy one ton Longhorn
BB
Old 06-15-2015, 02:45 PM
1Cool30's Avatar
It sounds to me like the Akerman angle is off due to either a bent steering arm or someone has replaced the steering with something with the tie rods in the front.
Old 06-16-2015, 08:32 AM
1971BB427's Avatar
There are chassis swaps used to clip these old Chevy trucks that use the tie rods up front successfully. The 2nd Gen Camaro subframes are a popular swap that works well, and all use front steering rods.
Something tells me this isn't stock front I beam axle, and/or it has been modified by either dropping the stock axle in the dirt, or changing the whole front suspension. Clipped front frame swaps can work well, but I've seen people attempt to use the control arms, and pieces by welding brackets to the stock frames, and come up with some nightmare steering issues.
Old 06-16-2015, 08:37 AM
Yes, there are plenty of front suspensions with the steering arms out front, but it's designed into the system! The tie rod ends are way out further to keep the angle correct.
Old 06-16-2015, 08:42 AM
1971BB427's Avatar
The key is using a complete engineered system, as it was originally engineered! Not that the system can't be installed in another type of vehicle, but it needs to retain all the proper geometry, as designed.
I'm guessing that's what is wrong with this truck, but I'll wait to suggest cures until we see pictures, and figure out what he's got going.
New spindles now steering problem 1baddeuce Suspension - Brakes - Steering 4 07-23-2015 08:25 AM
steering problem blue rose Suspension - Brakes - Steering 3 05-30-2014 08:13 AM
Steering problem genewa1 Suspension - Brakes - Steering 2 02-19-2007 04:00 PM
Serious steering problem! 68NovaSS Suspension - Brakes - Steering 3 08-25-2006 10:41 AM
OK, now what..steering problem Bluepen Suspension - Brakes - Steering 9 01-12-2005 06:51 PM
