Sticking hvlp gun trigger? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2016, 02:53 AM
Hi!
I bought myself a new hvlp gun, but the trigger seems to be sticky .
The trigger 'needle' ( dont know how you really call it?) returns quite slowly.
I did think about lubing it, but lube might hurt the paint job and cause problems?
Any advice?
Many thanks
Old 03-21-2016, 03:13 AM
Oh to add: it sticks only on the air part of the trigger pull
Old 03-21-2016, 06:08 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
That could be an indicator of wear on the air valve's bushing or improper adjustment. When that bushing is worn and the rod can tilt, it can dig into the trigger and be catchy when opening. Try backing off the nut a little. I used to keep a bottle of DeVilbiss Spray Gun Lube handy for this very reason. Used properly it doesn't cause problems.
Old 03-21-2016, 07:28 AM
Irelands child's Avatar
If it's a new gun, the valve packing might just be a too tight. You should be able to loosen it just a little then a light coat of oil - either a special spray gun or even sewing machine oil just rubbed on the pin should loosen things up. If not, take it back to the seller. If it's a mass produced Far East import like so many of the lower end guns, another one may be just fine. Don't be afraid to disassemble it - there is little to screw up though be careful.
Irelands child
Old 03-21-2016, 10:24 PM
Packing nut is too tight or it's not lubed. No lubey gun, no worky. Lube doesn't interfere with the paint job.
Old 03-24-2016, 11:16 AM
I cleaned it, reasembeled it and everything is fine now
There was a kind of sticky coating on the gun
hvlp, paint, spraying, sticky
Best HVLP gun for me? Mr_real365 Body - Exterior 8 10-28-2011 10:27 AM
HVLP air pressure set with trigger pulled? rpacker Body - Exterior 12 08-23-2009 08:19 AM
Want a New HVLP Gun Irelands child Body - Exterior 1 10-14-2006 10:54 PM
new hvlp gun? oldred Body - Exterior 1 01-30-2003 03:30 AM
New HVLP gun Biggarmike Body - Exterior 0 01-26-2003 08:46 AM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
