Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - street avenger issues
Old 11-26-2018, 08:01 PM
jjjaffo jjjaffo is offline
Originally Posted by TommyK View Post
It sounds like the transition slot is running out of fuel before the mains are fully flowing. Before you pull the carb apart you could try restricting the idle air bleeds with some small gauge wire and see if it improves. This will richen up the idle/transition. If it helps you know the problem is the ifr/iab relationship.
If you end up pulling the carb take a look at the t-slot exposure. If you have a lot of slot showing below the throttle blades the effective range of the transition circuit is limited.
I had actually forgotten about the wire trick. Thank you for bringing that to my attention. I will do that before any jet changes. Also my T-slot is almost but not quite square which should be pretty close to where it has to be.
