Street Beast Willys Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2007, 08:27 PM
HELP!!
I have a Street Beast 41 Willys. I'd like to put hydralic trunk prop cylinders on my trunk lid. My thougt is to run them down from the lid and mount them on the rear wheel tubes (inside the trunk). My question is; Has anyone done that, and how and where did you mount the cylinder bracket on the inside of the trunk lid? How far down from the top of the lid should I go to drill a hole---is there metal on the inside that I can tap and thread????
Thanks
Rick Dolinar
Old 06-25-2007, 06:03 AM
302 Z28's Avatar
On a glass body you will have to attach some form of support to the inner rear fender well. Usually this is a block of wood suitable large enough to spread the load out and provide attachment. How far down on the fender well depends on a lot of factors, like brand of lift your using and how high you want it to lift the deck lid. With the lift fully retracted sit inside the trunk and close the lid. Position the opener in a position where it will not bind. Mark the position both on the fender well and the underside of the deck lid. Now open the deck lid, extend the opener and position it on your marks. If there are no obstructions or binding that is probably a good mounting position.
Vince
Old 06-25-2007, 06:23 AM
Vince;
Thanks for your response---It's very helpful. I'm REALLY concerned about when I drill into the inner truck lid liner (what or how) can I attach the trunk prop hardware. I can't thread the fiberglass, and if there isn't any metal (or wood) sandwiched between the inner and outer layers of the truck lid, how do I attach it at that point??
Thanks Again
Rick
Old 06-25-2007, 06:44 AM
wildman1932's Avatar
Dave's hot Rod Shop
We have done this in our Hot Rod Shop, but I would not do it again! The constant pressure from the shock, in the hot sun, will allow the fiber glass panels to change the shape. I mean a lot !!!!!!! You would be better off with a linear actuator.
Dave Tallant KC Mo
Old 06-25-2007, 12:59 PM
Willys trunk prop
DAVE;
THANKS for your response----I REALLY do appreciate your words of experience. I'm thinking I better go the way you described!!
Thanks Again
VERY RESPECTFULLY
Rick Dolinar
Old 06-25-2007, 03:12 PM
302 Z28's Avatar
The gas lifting rods will deform the lid as they exert pressure constantly. I did not use them on my 34. I used a deck lid support from Rocky Hinge. This is a well made CNC machined deck lid support that locks over center. It is a nice piece of work and is a bargain at $70 compared to some of the traditional rod type.
Vince
Old 06-25-2007, 07:18 PM
Willys trunk Prop
THANKS VINCE!!!
Do you know if there is a web site I can go to inquire about Rocky Hinge?? I'll do a search and see if I can find anything.
Thanks again
Rick Dolinar
Old 06-25-2007, 07:50 PM
302 Z28's Avatar
Originally Posted by Rick Dolinar
THANKS VINCE!!!
Thanks again
Rick Dolinar
Yep, Rocky Hinge
Vince
Old 06-25-2007, 08:08 PM
Willys Trunk Prop
Vince;
Sorry to keep bothering you----I found Rocky Hinge when I did my search. I ordered a hinge. NOW MY QUESTION!!! Obviously the trunk of my car is fiberglass---Is your 34 also glass? If so how did you fasten the hinge to the inner panel of the trunk lid. If you bolted it did you thread the fiberglass or use some type of of toggle bolt mechanism?
Thanks Again
Rick Dolinar
Old 06-25-2007, 09:14 PM
302 Z28's Avatar
My deck lid has outer and inner pieces. I first marked the area where I wanted the upper attachment point and drilled two holes in the inner lid. The screws provided are for fiberglass and steel deck lids. The screws for fiberglass look like big wood screws. I intentionally drilled the screw holes a little smaller than required to give the screws more bite. The upper bracket holds real good as long as you do not get too physical with it.
Vince
Old 06-26-2007, 06:22 AM
Willys Trunk
VINCE;
THANKS AGAIN!!! You've been EXTREMELY helpful. I can only hope to assit you some day.
VERY RESPECTFULLY
Rick Dolinar
Old 06-26-2007, 06:33 AM
302 Z28's Avatar
VINCE;
VERY RESPECTFULLY
Rick Dolinar
Yer very welcome .
Vince
Old 07-04-2007, 07:40 AM
bentwings's Avatar
bentwings
I've used fabricated steel ( maybe stainless) brackets with holes drilled in them and glassed them drirectly to the fiberglass surface. The holes allow the glass and resin to bond better. Make them considerably larger area than normal where they contact the body or glass surface. In your case (and mine) I think partially filling between the liner and the exterior panel with expanding foam will strengthen the whole part.
I don't think I'd go with the gass struts as noted above. The linear actuator is ok. You wheel tubs shuld be plenty strong. Mine sure are. If in doubt add some plywood and metal thread inserts. Try Mcmaster-Carr for these.
This is how we mounted the bodies on the funny cars.
Old 05-02-2018, 09:49 AM
I put one on my Willys using a rivnut tools for the thread issue. You can get these tools at most parts houses or Harbor Freight (if you don't plan to use it a lot). It works like a pop rivet tool but installs special threaded nuts, called riv nuts.
Old 05-02-2018, 05:33 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
11 year old thread.....just sayin'
StreetBeast rod kit's donaldm605 Hotrodders' Lounge 1438 12-08-2016 07:17 PM
street rods Robert Podgurski Hotrodders' Lounge 18 11-27-2008 05:18 PM
Tire Tricky question Ratoflic Hotrodding Basics 3 01-14-2005 03:06 PM
Street Beast kits Hot Rod Hellion Body - Exterior 3 03-15-2004 08:25 AM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
