Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - street motor
Thread: street motor
  #18 (permalink)
Old 08-19-2019, 03:04 PM
64nailhead's Avatar
64nailhead 64nailhead is offline
Originally Posted by skinnymike View Post
Thank you techinspector and Bogies. Those ideas add to my info base so I won't get something disappointing. Don't need or want 500 hp or a motor that needs 6000 rpm to run. Just a fun street motor. Thanks.
It sounds as if you're not extremely knowledgeable about build/motor specs. Re-read TI's last post- - that is a small cam (implying low RPM) 383 with mild compression that will be EXTREMELY streetable and will hall the mail in a 4500lb truck. Put it in your 2500 unit and it will make you feel as if you're delivering the mail via air...lol. I reiterate 'streetable'.
Being 'streetable' comes down to cam specs. So a mild cam will be more streetable. To overcome the 'streetable' you need some additional cubes, hence the 383.
FWIW - I LOVE to haul the mail and I'm sure you will as well.
The Following 2 Users Say Thank You to 64nailhead For This Useful Post:
123pugsy (08-24-2019), techinspector1 (08-19-2019)
