subframe connectors - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2003, 01:02 AM
New Member
Post subframe connectors
i have a 70 camaro and need to add subframe connectors and was woundering what is involed in this. also how hard of a job is it to do. thanks any help would be great
Old 02-17-2003, 02:51 PM
Canzus's Avatar
a red wool sock on his dinger
Post
It depends, If they're bolt in, or weld in...
Old 02-24-2003, 10:47 PM
New Member
Post
is one better then the other. i mean is the weld in ones any better then bolt ones and if so what kind of Advantages does it have.
Old 02-25-2003, 05:03 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T...
Wiki Edits: 2
Post
Bolt in will just bolt up after drilling a couple holes. They are not as rigid, and tend to eventually wear the holes and not do much good. I would get the weld in or weld the bolt on connectors after they are attatched.
Chris
Old 02-25-2003, 11:52 AM
Post
I just bought a set from jegs. Ended up buying the Comp. Engineering ones that bolt in because I didn't want to modify the rear frame rails. (Not yet anyway) As per the Comp Engineering instructions, I plan on welding these in for the added strength though.
Just be careful if you order a set from whoever that you don't have to modify the rear frame to accept the connectors.
~Michael
Old 02-25-2003, 09:43 PM
New Member
Post
what kind of work is involed in this.is it just something i jack up the car and its all done under the car or do i have to take any panels off.i have very little exp. with this section of the car.(more of an engine guy)how long does something like this take.could it be done in a day or is it one of those weekend jobs because i haft to drive my car to school.
Old 02-26-2003, 08:09 AM
TurboS10's Avatar
Wiki Edits: 2
Post
It takes about 2 hours or so to bolt them in. Very simple.
Chris
Old 02-26-2003, 04:59 PM
New Member
Post
thanks for all the help you guys are great.
