Sun distributor machine - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-18-2014, 11:41 AM
Guest
I probed the connector and couldn't read any voltage. The pigtail has been added so I guess i need to go inside the machine to see where and what it is doing. I didn't see it when i redid the mechanicals and table etc, I didn't have that side of the machine apart.
It looks like a ford plug to me, anybody recognize it?
ID:	113705   Click image for larger version
ID:	113713   Click image for larger version
  #17 (permalink)
Old 01-24-2014, 08:24 AM
Guest
Originally Posted by Denny View Post
Ok, that's used for the trigger. To flash the light each time a cylinder would fire. It shows the spark pattern on the distributor machine. As in making sure each cylinder fires at the same time, by comparing the pattern.
Here's a diagram I found, and as you see, it is the pickup, pole piece, reluctor. (they have 3 different names), but mean the same thing.
You may still need a voltage supply
http://nnyoffroad.com/wiki/images/b/...k2-diagram.gif
Is this it? I pulled the cover off one side of the machine to expose this add-on module, it looks like it is from a Ford.
The stud on the left is isolated and something clips to it - i think the alligator clip from the internal strobe light of the machine clips to it.
What hooks into the plug/connector - the box has no seperate power supply, one of those wires must be +12v supply for the box and the other 2?
Thanks, oj
ID:	115561   Click image for larger version
ID:	115569   Click image for larger version
  #18 (permalink)
Old 01-24-2014, 10:13 AM
Guest
That box IS the Ford ignition module. That plug in plugs into a Ford distributor for testing. Same as it would be on the vehicle itself.
The Red & Green wires went to the post on the side, they were joined; the stater (purple & orange) and ground (black) go to that plug extending on the pigtail. If i read the scematic right the Red is +12v and the green is trigger for the coil, thye should not be joined. It looks to me i should join the Red & White and give them +12v; the green would go to strobelight & ground side of the coil. The Purple & orange to the magnetic + & - pickup and the Black is ground @ the distr - is this right?
Can i both trigger on the Green the stobe light and fire the coil at the same time or will i get 12v thru the coil and damage the internal workings of the Sun, maybe do one or the other but not both?
The Red and Green wires joined and connected at the post is what is giving me pause.
  #19 (permalink)
Old 05-16-2016, 09:30 AM
LED upgrade
I have converted a model 504 with faulty flashtube to LED. If anyone is interested I can supply a kit to do this. It eliminates/replaces all the old high voltage electronics. Many different models use the same circuit as the 504. PM me if interested.
  #20 (permalink)
Old 05-16-2016, 06:53 PM
sun distributor machine
How about a little more info? What's involved in the changeover? Will it work on my 506? And, of course,
what kind of expense is involved?
Gary Kosier
  #21 (permalink)
Old 05-16-2016, 07:22 PM
If you would like to contact me privately with your email address, I would be more than happy to send you the changeover instructions. It's a 3 meg pdf file with complete instructions and pictures. From that you should be able to determine if it is suitable for your machine.
  #22 (permalink)
Old 05-23-2016, 05:48 AM
Sun 600 Dist Machine
Hi StuV,
Can you email me the pdf, will it fit the 600 model
  #23 (permalink)
Old 05-23-2016, 12:31 PM
Hi Dan Tim
If you supply me your email address I will be happy to send you the installation instructions. You should be able to determine if it will work for your machine from that.
  #24 (permalink)
Old 05-23-2016, 01:24 PM
Sun 600
Hi,
I'm sorry, I thought you could glean it from clicking a user name.
[email protected].
Thanks,
Dan T
  #25 (permalink)
Old 07-12-2016, 11:11 PM
YES, it will work on the model 504.
  #26 (permalink)
Old 06-17-2017, 11:18 PM
I would like the information if still available.
[email protected]
Thanks
Sent from my SM-N910R4 using Tapatalk
The Following User Says Thank You to fuelie74 For This Useful Post:
Frankie desoto (02-06-2018)
  #27 (permalink)
Old 02-06-2018, 10:09 PM
Hey stuV do you still have the led upgrade for the sun distributor machine and will it work on a mdt.
  #28 (permalink)
Old 02-06-2018, 11:01 PM
Yes I still have the distributor machine LED kit and it will work with ANY machine including the MDT. If you contact me privately I can give you the details.
  #29 (permalink)
Old 02-06-2018, 11:26 PM
Don't have enough postings to do private. Here's my email [email protected]
  #30 (permalink)
Old 02-06-2018, 11:37 PM
Sorry stuV the email is [email protected]
