super budget 92 camaro turbo build - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #91 (permalink)
Old 07-01-2013, 12:28 PM
Project89's Avatar
Originally Posted by vinniekq2 View Post
Is the car laying down on the top end or is it just like that with small engines?8.2,, 1/8 was thinking 12.5 ,,1/4?
I just figured the turbo would have more top end charge?
congrats on a 12
when my car was running the same times it was identical , only would pick up 20-21 mph on the top end.
i do believe its a converter issue in high gear, we already know his converter is slipping pretty dang badly, i suspect in high gear with all the load its just slipping away a ton of power.
i had the same issue in my car until i swapped it out for a tci ssf converter that i had reworked. Once i swapped the converter on my car i would pick up 23-26mph and droped a few tenths off my et
i have to get the datalogs from him and look over them to know whats really going on though, have to get him to install a driveshaft speed sensor if his ecm can log it
btw thanks going to try to get him to 11.90s in the fall
  #92 (permalink)
Old 09-06-2013, 02:45 PM
Project89's Avatar
damn ive forgot to update this
anyways his car is now running 12.70's with 1.6 60'fts and he still hasnt turned the boost up
just recently like the last few days he put new valve springs in it , i was unaware that he was running stock valve springs so he was losing power on the top end, new comp cams 981 springs installed and now the engine pulls hard all the way to redline so he should pick up a few tenths and a bunch of mph.
i belive hes going out tommorow to run the car ill post results
ill also post up his slips and videos from the 12.70 passes
  #93 (permalink)
Old 09-06-2013, 10:10 PM
vinniekq2's Avatar
looking forward to the video
  #94 (permalink)
Old 09-08-2013, 04:52 PM
Project89's Avatar
i made a mistake before car went low 12.80's , he had it out yesterday but the turbo header is cracked halfway around the #5 primary tube and it was very laggy , car only ran a 13.40 but instead of picking up only 20/21mph on the top end he picked up almost 26mph
so he was deffinatly floating the valves with those stock valve springs at rpm before and loosing power
  #95 (permalink)
Old 09-08-2013, 09:20 PM
vinniekq2's Avatar
thats racing,if something can break it will,if it cant break it will
  #96 (permalink)
Old 11-16-2013, 11:24 AM
Everything is HAMMER!
Cool to see this thread is still going, and because of this thread I'm now underway on my very own turbo project. My 1992 s10 350/700r4 is getting an undercab mounted gt45, i"ll be running a Hangar 18'd blow thru holley 750 dp and I'm hoping for something around 500rwhp(turbo is capable of 600whp). The best part will be that I'll still be getting 20+mpg and have a stock like idle. There just doesn't seem to be a downside about making power with turbo's, well, except for finding the weak points in your drivetrain.
  #97 (permalink)
Old 11-30-2013, 06:47 AM
Project89's Avatar
i havent updated this in a while , but he ended his season early to tear down the engine.
hes building a hybrid 3.1/3400 engine , basically a rwd shortblock , with a fwd topend
i tried to talk him out of it as with some driveline upgrades his combo was capable of 11.70's
the hybrid engine will make more power alot more actually but im afriad with his current driveline hes going to have alot of trouble getting that power to the track
  #98 (permalink)
Old 11-30-2013, 06:50 AM
Project89's Avatar
if i may i suggest not going with the carb , i would go with a megasquirt 1 or 2 ecm and a stealth ram intake , it will cost a lil more in the beginning but the tuneability u gain from the system is well worth it
while carbs can work very well its not something i recomend for a first time turbo system
also if it is infact ur first time doing a turbo build i recomend u dont spend a whole lot on the engine most first time build do end up with a hurt engine while the person trys to knock out the tune
  #99 (permalink)
Old 03-11-2014, 12:01 AM
Project89's Avatar
cars almost back together it will deffinatly run mid to low 11's this year and should run into the 10's pretty far
the engine is sporting a few upgrades this year
bored .030 over and new speedpro dished pistons displaces 3.25L now instead of 3.1L
3400 aluminum canted valve large port heads are going on it this year, heads flow 100 cfm more out of the box then the old cast iron heads flowed ported
also building a real set of headers for it
  #100 (permalink)
Old 03-18-2014, 05:55 AM
Project89's Avatar
hes getting closer
  #101 (permalink)
Old 05-22-2014, 03:07 AM
Project89's Avatar
cars back up and running
swapped to aluminum canted valve heads
added an intercooler
cant rember if he stepped up to the 272/272 cam or if he is still using the 260/260 grind
new engine sounds good
  #102 (permalink)
Old 05-25-2014, 04:24 PM
Project89's Avatar
at the track In 2nd round now. Best of a 12.49 so far at 110mph. Launching soft.. 1700rpm. 1.9x 60 foot times. 12.5psi. Ill add video of run later
  #103 (permalink)
Old 05-25-2014, 04:54 PM
Project89's Avatar
12.45 at 111 lost 2nd rd
  #104 (permalink)
Old 05-25-2014, 09:54 PM
vinniekq2's Avatar
good mph for E.T.
  #105 (permalink)
Old 05-26-2014, 12:22 AM
Project89's Avatar
1st round win mustang gets the head start
build thread, camaro
twin turbo 350 on a budget?? mikeweyman Hotrodding Basics 24 11-16-2010 11:03 AM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
budget turbo set up 409guy Engine 12 08-22-2006 05:40 PM
Turbo VS Super Icebergslim1827 Engine 29 04-24-2004 09:52 PM
super/turbo madhat Engine 0 06-22-2003 01:15 PM
