Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Suspect front brakes doing all the work?
Old 07-30-2018, 12:04 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Are your rear shoes adjusted properly? I assume you have a proportioning valve in the system, otherwise your rears would be locking up early. Isa this a power brake system?
If this is a large bore GM master cylinder, they have a different depth rod 'seat' in the rear, do you have the correct length for your MC?
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
RWENUTS (07-30-2018)
