suspect my C-4 needs a reseal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2011, 03:44 PM
Hi ALL, my C-4 trans tried to puke it self to death when I put it in reverse after a cold start. It appears the front seal is gone and don't know what else or the cause of it all. Anyone with knowledge of C-4s it's an '82 out of a firemont wagon that was gone thru before I got it. Will gladly accept any info that will help. Thanks C.C.
Old 11-25-2011, 10:34 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
slow shifts on a C4 usually mean the seals inside of the trans are hard and causes slow shifts when cold.As the oil and trans warms up,it gets a little better.Sounds like you need a overhaul there.Some of the Fairmonts and Mustang II's had C-3 transmissions as well,with same results.
Good luck,Paisano
oil leak at back of intake- how to reseal? c_cham Engine 16 12-16-2010 09:14 PM
85 Chevy s-10: won't start, suspect elec probs now joe99 Electrical 7 12-15-2010 12:58 PM
Gas tank To Reseal or Buy New newdad1 Body - Exterior 4 05-04-2009 01:04 AM
New motor runs rough ,suspect timing - need help Joe 570 Engine 6 04-23-2006 10:42 AM
How to reseal timing chain cover to oil pan shockers69 Engine 2 06-21-2005 10:55 PM
