T-350 Input shaft types early vs late - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 10-23-2012, 06:22 PM
Hey. I had to order a new forward drum w/ input shaft.
But they sent me one with the later style input shaft that has the teflon seal where it goes in the output shaft.
It will fit now that I pulled the bushing........but the shaft is 1/4" shorter than my old one.......and the spline length on the input side is not as long either.
Will this work or should I get the earlier style drum/input shaft?
Thanks, z
Quick reply to this message
Old 10-24-2012, 06:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks, z
If by "later style input shaft" you mean the shaft is for the TH350C w/lock up torque converter (used 1981- up), a non lock up torque converter will not fit the lock up style shaft.
If this is the case, get the older non lock up style input shaft.
Old 10-25-2012, 07:47 AM
No that's not it. Chevy upgraded the input shaft in 77 or so.......when you pull the bushing out of the output shaft, the newer style will fit ........but I worry about it being 1/4 inch shorter.......and the spline length being shorter too.....Sessions talks about the bushing/newer teflon seal....but doesn't elaborate on switching them......
z
Old 10-25-2012, 07:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I toss out the shaft with the teflon seal....
the nick is nothing to worry about, unless there is a crack. oh wait, that question was on yellow bullet forum
Closed Thread
forward drum, input shaft, th350
T56 magnum input shaft and main shaft upgrades Powellbr Transmission - Rearend 1 01-09-2017 08:33 AM
T-350C input shaft in T-350 stevetankl Transmission - Rearend 6 03-26-2016 07:00 PM
What spline is my T-350 input shaft? dually502 Transmission - Rearend 9 05-14-2014 02:20 PM
Excessive input shaft endplay (T-350) ntx_gearhead Transmission - Rearend 6 11-14-2010 04:33 PM
early model vs. late model 350 blocks quincysmith Engine 11 08-15-2007 11:12 AM
