T-350 speedo calibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2017, 11:19 PM
th350 non lockup trans with small driven gear housing hole 2.50 rear end gears 205/70 15 tires 26.3 tall what color/tooth count do I need for drive and driven speedo gears new build have not driven
Old 03-16-2017, 06:55 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I moved your thread from Introduction forum to the Transmission forum.
Tech questions are not often seen in the introduction forum.
Old 03-16-2017, 08:27 AM
delawarebill's Avatar
driven gear
first do u have a gear to put in and be able to run it??? if no then there are a few web sites (summit/jegs) that have a calculation table to fill in the blanks and it's give u the driven gear teeth. now if u do have a gear to use, put it in and drive it with a GPS going and looking at the speedo. 60 is a good mph. then divide the big number into the small to get a percentage. then multiply that % to the driven gear teeth count and u'll get the number of teeth to add or subtract to that one. i did the last part on my fairlane and it worked very well.. the web sites were a royal pain.
Old 03-16-2017, 08:37 AM
RWENUTS's Avatar
Look here for calculators and the gears you need.
https://transmissioncenter.net/shop/
speedo calibration, th350
speedo and fuel gauge calibration smoking 59 Electrical 8 03-30-2015 08:46 AM
Autometer speedo calibration? Localboy808 Hotrodding Basics 5 05-09-2012 07:48 PM
89 GMC Speedo Calibration Alaska_Man Electrical 1 11-30-2010 03:57 AM
speedo calibration problem solvers Introduce Yourself 1 08-10-2006 08:31 PM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 08:46 PM
