T-400 issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2020, 12:42 PM
T-400 issue
Everything shifted fine, all gears worked. The shift modulator ended up getting cracked going inside the trans. This was 3 years ago when it happened. Its my demolition derby trans. And I couldn't get the modulator in time for the derby. So I just jb welded the crack. Jumped into the car and it had no reverse. Can the shift modulator cause it to not have reverse? I don't remember if it had all forward gears or not. I really don't want to put it back into my derby car to test it to just pull it back out to swap everything from my bop th400 with a bad case into the th400 without reverse.
Old 08-02-2020, 01:54 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
The best modulator on the planet is still under 25 bucks. Skin your wallet Dude.
Old 08-02-2020, 03:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The vacuum modulator will not cause a "no reverse" situation if the other gears function correctly.
Old 08-02-2020, 06:27 PM
That's kinda what I thought. Just wanted to make sure before I spent the time to swap internals over. Thank you
