T.B.I Vortec GM Performance Manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2016, 06:26 PM
I pulled a 5.7L out of 1998 suburban to have an engine with the Vortec head and am fitting it into my 1994 K5 Blazer using the GM Performance TBI Vortec Manifold. Anyone done this one? Do i need to ensure the bypass from manifold to water pump is installed? Any problems to watch out for?
Old 01-05-2017, 04:11 PM
It's easier to drop back and use the LO5 water pump (1987-1995). This keeps all the vehicle connections and the bypass the same as what you have. The only thing that sometimes crops up is sealing the old bypass hole(s) in the lower right (passenger) side horn if either the block's or pump's hole doesn't have a match. If a hole is exposed just tap it and screw in a plug.
Bogie
5.7, t.b.i., tbi
Jet performance chip for 5.3 Vortec? Torque454 Hotrodding Basics 4 06-09-2014 11:04 PM
SBC cast iron Exhaust manifold performance 49willard Hotrodding Basics 74 12-26-2012 10:21 AM
Summit Racing vortec heads VS GM Performance Vortec heads jsm1847 Engine 3 05-29-2012 07:01 PM
vortec heads bolt on performance? 77stepside Engine 15 12-31-2008 08:08 AM
Performance heads/manifold/carb. for a flathead first timer Engine 1 12-08-2003 01:13 PM
