Tachometer trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2016, 05:52 PM
EragonSuperH's Avatar
I invent stupid usernames
Tachometer trouble
The tachometer I put on my 1978 GMC truck is acting up. When the truck is idling, the tach will be pegged out, then when I rev the truck up, it will drop down to zero RPM on the tach, then at highway speed (around 60 MPH), it will say somewhere around double the RPM it should be running.
Tach is Equus model 6086 and it's not a problem with the tach as it's the second one that's done this. Switch is set to 8 cylinders, and as far as I can tell all of the wires are connected properly. It could be that the ground wire is connected to the valve cover, but I doubt it.
Engine is a small block 350 with HEI ignition.
Any thoughts or comments?
Old 01-09-2016, 09:34 PM
4 Jaw Chuck's Avatar
Low quality tach, unknown ground wiring.
Start with the ground.
— Han Solo
Old 01-10-2016, 06:21 AM
64nailhead's Avatar
The ground wire needs to be located on a clean ground and not near any of the plug wires or coil wires (if your HEI is a coil in cap HEI, then this won't be an issue.) The same consideration needs to be given to the tach signal wire.
Old 01-10-2016, 09:15 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Troubleshooting 101:
Temporarily connect the tach to a different engine and see if it works properly or not. This immediately tells you if the problem is the tach (or associated installation) or the vehicle it's installed on.
The Following User Says Thank You to joe_padavano For This Useful Post:
64nailhead (01-10-2016)
Old 01-10-2016, 03:10 PM
Are you sure the wiring is correct?
Sounds like you have the signal and ground wires reversed.
Does the tach light work normally?
Old 01-11-2016, 05:15 PM
Yes the light works perfectly fine. The funny thing is, the tach will actually sometimes work in a certain rpm range.
Old 01-11-2016, 05:16 PM
I will check this out. I had it grounded inside the cab, and to the valve cover, with no difference.
Old 01-11-2016, 05:47 PM
rdobbs77's Avatar
Huge Guns N Roses Fan
Are you running MSD?
Old 01-12-2016, 03:55 PM
Nope. Stock GM HEI coil in cap distributor.
Old 01-12-2016, 07:35 PM
Originally Posted by hcompton View Post
Is this an after market tach. Do you have it in v8 mode and not 4 or 6 cylinder mode. Most can support all three and will act up if not in v8 setup.
Yep it's aftermarket, and yes it's set to 8 cylinders as I said before. This is really baffling, but it's too cold to work on it now. You're right that it can support all three, I made very sure of that
1978, 350, not working, sbc, tachometer
Tachometer Charlie's 33 Ford Electrical 6 01-14-2014 07:50 PM
tachometer Larry Buckner Electrical 2 11-04-2008 02:48 PM
Tachometer viking Electrical 4 09-11-2007 08:10 PM
tachometer douhavit Electrical 3 06-09-2004 08:08 PM
tachometer grapro Electrical 3 05-29-2004 10:23 PM
