Tap and drill cutting fluid "oil" - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2015, 09:14 PM
A while ago on the forum someone told me about using "cutting fluid" for cutting threads with a tap. I don't remember who it was but wanted to thank them (again I think). I have been using it now for a while and I just have to scream from the roof tops how great this stuff is!
If you haven't used this stuff, it is a GREAT help with drilling and tapping.
To who ever told me about this, THANKS!
Old 01-03-2015, 09:27 PM
BOBCRMAN@aol.com's Avatar
Yes, great stuff.. I keep a can next to the drill press..Years ago, a now deceased friend, used to get some tap fluid from his job at the GM tech center. Stuff had a strong cinnamon smell and was sooooo good.. Made tap-magic look like drain oil..
Old 01-04-2015, 08:21 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Brian, I've been using the cutting fluid for years I don't do much drilling and tapping but its REALLY handy for drilling out spot welds...
What I do is put a bit of foam in a small can (canned mushrooms) then put the fluid in it so when I knock over the can it don't spill ,the foam holds it in there...One day I put the can in a magnetic bolt tray I got from HF for a couple bucks and now I can stick the cutting fluid any where and keep it off the floor when cutting my welds ...Putting it in the magnetic bolt tray has an unexpected second purpose ,I now have a place to keep the various drill bits I need along with the fluid ...very handy...
Old 01-04-2015, 08:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
we use a paste product : Jokisch Econo 897 on the mill . Makes for less mess on the bed of the mill.
Basic tapping: Tap Magic or Ridgid brand liquids
Old 01-04-2015, 09:45 AM
I think you are the one who told me to try it Mike, and I will try your can and foam too, awesome!
Old 01-04-2015, 10:44 AM
Cutting fluid
One of the best..Rapid Tap.
The Following User Says Thank You to dannronn For This Useful Post:
MARTINSR (01-04-2015)
Old 01-04-2015, 11:08 AM
Unless I try it side by side I imagine it would be hard to tell which is better but I will give it a try when I am out of the one I got. But the cool part is, you use so little it will last a LONG time!
Old 01-05-2015, 06:11 AM
Wiki Edits: 11
Now THAT sounds cool ,I guess it melts as it heats up ? it would be less mess than oil for cutting welds too. I never heard of it before.
Old 01-05-2015, 06:20 AM
Irelands child's Avatar
Last wiki edit: Ford engine specifications
I've been using Cool Tool ll for years. It has worked well for me. Even used it at GE way back in the '70s when I ran a small machining area.
I like that small can with a piece of foam idea. I always have a greasy spot on my bech from that single drop that runs down the side of the can every time I use it.
Dave W
Irelands child
Old 01-05-2015, 10:16 AM
1971BB427's Avatar
I've used Rapid Tap, and Tap Magic for years. I use them for both drilling and tapping, and love both. Rapid Tap used to be a very thin viscosity, and worked well, but didn't stay on the tools well. They changed to the thicker formula, and that's when I really liked using it. I've got cans of it everywhere I might do much drilling or tapping.
$100 screw cutting 12" lathe/mill/drill design rigmatch Garage - Tools 1 12-08-2011 11:17 AM
Th350 Fluid "Flood" Oldskool1060 Transmission - Rearend 2 02-24-2009 06:56 PM
Brake fluid "evaporation" ChevelleSS_LS6 Suspension - Brakes - Steering 1 09-16-2006 02:41 AM
"Question/Help"cutting or removing exhaust & Catalytical converter system sungho General Rodding Tech 4 07-29-2003 12:35 AM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
