Tbi to Carb swap parts list. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2015, 01:32 PM
Im just looking for someone to check my parts list for my tbi to carb swap on my 1994 chevy k1500 with the 350.
I have a holley 600 cfm classic carb
holley 12-803bp fuel regulator
holley carb tps sensor for the 4l60e
edlebrock 2104 performer for the 88-95 trucks
hei distributor
misc fittings for the carb and fuel regulator.
im not sure if I can keep my throttle cable or if I have to order a new one for the carb.
I have the moates chip burner to tune my 1227747 ecu into a stand alone for the 4l60e
Is there anything super obvious Im missing for this swap?
Im planning on cutting the fuel lines close to the firewall and flaring them to run rubber lines to my regulator. That way if I don't like the carb setup or it doesn't run well enough to be a dd in harsh nh weather, I can convert back easy enough with some adapters to the tbi.
Also anyone who has done this swap, any tips or tricks or is it pretty straight forward from here?
I know this topic has been done a million times for tbi trucks, im just looking for someone to verify my parts list. Thank you in advance.
Old 06-23-2015, 01:49 PM
hei distributor
Looks good.
Bogie
Old 06-23-2015, 02:41 PM
Awesome. Thanks man
Old 06-23-2015, 03:21 PM
Thanks. I do remember something about the fuel pump relay in other threads. I wonder if I can tune that out... I might go with that intake if I can find it for a bit cheaper. Carb intakes for 88+ are pretty sparse as far as I can see unless I buy no name. I'm trying to get through this as cheap as possible so it doesn't over eat into my budget for a carbed 5.3 swap eventually
Old 06-24-2015, 12:43 PM
Since you're keeping the existing computer in the circuit the fuel pump will be fine. The computer is looking for a tach signal which you need for the tranny anyway when it see revs higher than cranking RPM it stops the time out sequence and locks in the pump relay.
Bogie
tbi
Parts list for TBI to Carb ChevroletSS Engine 30 12-20-2012 07:27 PM
289 to 351W swap parts list 351WTripleBlack Engine 1 06-12-2010 03:55 PM
TBI to carb swap eatonde Engine 20 09-09-2008 11:01 AM
Carb to TBI Swap? mrevil General Rodding Tech 2 03-26-2005 09:38 AM
Tbi To Carb Swap strracer7 Engine 5 08-05-2004 12:13 AM
