Temp sender - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2018, 09:02 AM
EragonSuperH's Avatar
I invent stupid usernames
Temp sender
I'm looking for a temperature sending unit that has the same ohm ratings as the ACDelco G1852 but with a 3/8" NPT thread. I can't seem to find anything
Sent from my VS996 using Tapatalk
Old 11-07-2018, 09:38 AM
Most if not all temp senders use a 1/4 pipe thread for some reason GM taps this 3/8ths . Most gauge kits include adapters. If not a decent hardware store should have a 3/8ths pipe to 1/4 pipe bushing, problem solved. Same thing if the head is a half inch pipe thread, just bush it to connect the two parts.
Bogie
Old 11-07-2018, 09:41 AM
Bogie
Do you know of any sending units that meet the requirements? I suppose a quick Google search on my part would answer that
Old 11-07-2018, 03:21 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
What is it you're trying to do? Do you have an original OEM gauge that you want to use, but don't have the original sender for it?
Old 11-07-2018, 03:44 PM
I have an oem gauge that I'm trying to use with aftermarket heads
Old 11-07-2018, 07:49 PM
I believe the hole for that sending unit is on the side of the block(drivers side usually) though not in the head. A good alternative is using the intake port next to the thermostat. You may need to tap the intake. But it works if you don't want to have the sensor down near exhaust.
Old 11-07-2018, 07:57 PM
There is no port in the block, its in the head. And yeah I'll be using the port next to the thermostat because it's the same thread size as the original sending unit that is currently in the thermostat housing
moving water temp.sender chevynut1 Engine 2 07-26-2005 06:37 PM
Aftermarket Temp Sender? Seon Engine 11 10-29-2004 09:31 PM
sun water temp sender 1949olds Introduce Yourself 1 10-20-2004 05:47 PM
Engine temp sender location head/manifold question. Blown72Camaro Engine 5 08-27-2003 11:43 AM
Replacement of Temp Sender PrimaDude Engine 6 11-28-2002 12:52 PM
