Think maybe i did this wrong! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2019, 08:56 AM
bsa_bob2's Avatar
Here are 3 pictures of my car trailer ...raise and lower tongue...crank.It was a press fit -and the handle broke off after hauling my sons full kustom 50 Merc he had just bought for $ LOW dollars,, ....anyway! please look at this crank i peened over the bottom end[just the crank pin] then rewelded it back on..
I can't say i did it wrong but...........but didn't pay attention reattaching the crank handle,If you can't help//its ok..............jus means i gotta drive 25 miles to ask the place that sold it to me and ask them.Is it wrong or is it correct thanks much bob s
Name:	trailer handle correct 001.jpg
ID:	445513   Click image for larger version
Name:	trailer handle correct 002.jpg
ID:	445515   Click image for larger version
Name:	trailer handle correct 003.jpg
Old 07-28-2019, 09:04 AM
delawarebill's Avatar
handle
i don't see an issue.. it's been repaired on both ends and as long as it holds up your fine.. the handle can be just replaced if u have a concern. only go to the trl joint to get a new one..
The Following User Says Thank You to delawarebill For This Useful Post:
bsa_bob2 (07-28-2019)
Old 07-28-2019, 09:10 AM
bsa_bob2's Avatar
i only welded the pin back on the arm, my concern was if the arm was upside down when i welded just the handle pin back on maybe it works either way? bob s
Old 07-28-2019, 10:15 AM
bsa_bob2's Avatar
welded it right----just flipped it over/// all good now thanks Delawarebill
Old 07-28-2019, 06:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You messed up by not putting an electric one on it.
Old 07-29-2019, 08:17 AM
bsa_bob2's Avatar
Funny you should mention that?....AS....i was going to see ,if anyone could share with me where to get 25' of new winch cable . My has broke strands.I tried the company.No way to get into their fb page. Mines a putnam Superwinch.x3 ~~~~~bob s
ps; mine has seprate removable "winch."It never sees bad weather bob
Old 07-29-2019, 09:27 AM
You want 1/4" wire?
Old 07-29-2019, 12:08 PM
bsa_bob2's Avatar
my winch for car trailer??
We pulled a finished 50 Merc onto my tandem Axel kar trailer.hauler with this cable size.1/4".Can someone share with me how to get this wire back on the inside of reel .It Dead ends inside -behind -its destination. Has allan head set screw,- that tightens against the cable...but.............Theres a ring or a cap, inside on the very end of the cable.MAN!i have no idea how to hook this all up.Simple is it~ or am i just missing the boat here. and thank you for coming by bob s
I know its old .but.............so am I
Name:	trailer winc 001.jpg
ID:	445597   Click image for larger version
Name:	trailer winc 002.jpg
ID:	445599   Click image for larger version
Name:	trailer winc 003.jpg
Old 07-29-2019, 12:26 PM
IT look like you're gonna need to take the drum off. At least the support.
Old 07-29-2019, 02:18 PM
bsa_bob2's Avatar
Theres a small steel band~ around the cable end inside the drum.. CAN I--[anybody] --remove this band? ,Is it welded on or sweated on? THANK YOU much for helping me bob s
Old 07-30-2019, 09:20 AM
I'd guess neither.
Maybe cut the cable about 2" from the drum and push it through the drum (between the support and drum) AFTER loosening the set screw.
