Thread locker=Thread sealant - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2019, 06:41 PM
briansansone's Avatar
4 chevys and a ford
I got a splice in cooling system drain. Its an aluminum tube, with a screw in
brass petcock. I assume I have to use something to keep coolant from leaking past the threads. I worry that if I just use traditional thread sealant, when I go to open the petcock , the whole piece may unscrew; especially as it ages and gets beat up. Will thread locker seal it?
Old 07-09-2019, 07:14 PM
Locker will seal it. Removing the petcock risks taking the threads out of the aluminum, so you probably want to use a small valve than a cheap petcock as they do frequently fail. Or install an intermediate fitting so the adapter tube's threads don't take the petcock's installation loads.
Coolant is sneaky stuff it works hard to find away out.
Of late I've taken to using the thicker, oil and fuel resistant yellow Teflon tape thread sealer on bolts and fittings with excellent results.
Bogie
Old 07-09-2019, 07:19 PM
ball valve, nickel plated, Grainger has them
Old 07-09-2019, 08:01 PM
4 chevys and a ford
yea I was looking at some of those, but I wasnt sure about the heat and pressure, and longevity with heat and pressure.
Old 07-09-2019, 11:37 PM
They last very well.
Bogie
