Throwout bearing shaft play - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2018, 10:06 AM
I'm setting up a conventional external slave/clutch fork throwout bearing on a Tremec TKO xmsn. What would be considered normal radial play between the throwout bearing and the xmsn input shaft bearing retainer outer surface the t/o bearing rides on? Thanks.
Old 06-20-2018, 10:50 AM
make sure you check your bellhousing/block/crank as an assembly for concentricity and parallelism (using a dial indicator. Most Tremec sellers really like roller pilot bearings, which dont tolerate misalignment well, and neither do the bearings in the gearbox itself.
Whoever sold you the hyd. kit and your TKO should be able to supply you with the amount of radial play they (both) deem acceptable, this also keeps you from running afoul of any warranty issues with the hyd clutch or gearbox. Cover-your-butt 101.
If the gearbox seller and the hyd master/slave both give you the same range...you're good.
Old 06-20-2018, 01:03 PM
Thanks, Autogear. I've done the checks you mention and all is within limits. Just didn't see any reference to the play I enquired about. Incidentally, I did contact Tremec about recommended pilot bearing vs bushing for their recommendation. Tremec said they have no preference. I went with bushing (oilite, confirmed non magnetic).
The Following User Says Thank You to bob70 For This Useful Post:
AutoGear (06-20-2018)
Installing throwout bearing.... muscarmad Transmission - Rearend 0 09-07-2010 06:48 AM
Throwout bearing for BB Chevy. camarochas Engine 23 05-11-2010 09:48 PM
Causes of bad throwout bearing? BMM Transmission - Rearend 5 02-15-2007 06:42 AM
Throwout bearing clearance GCD1962 Transmission - Rearend 2 01-23-2006 06:37 PM
Throwout Bearing johnsongrass1 Transmission - Rearend 4 04-07-2005 03:35 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
