Timing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2016, 07:02 PM
Timing?
2004 Chevrolet 350, when coming to a full stop or backing up it sounds exactly like a diesel engine, pinging and rattling and shaking. Anyone heard of anything like that? My mechanic was stumped.
Old 07-01-2016, 08:48 PM
rdobbs77's Avatar
Huge Guns N Roses Fan
Have you checked to make sure your motor mounts are not loose,
The Following User Says Thank You to rdobbs77 For This Useful Post:
36 sedan (07-01-2016)
Old 07-01-2016, 10:01 PM
I have not. The pinging and dieseling wouldn't come from loose mounts tho would it?
Old 07-02-2016, 06:48 AM
rdobbs77's Avatar
You mentioned shaking which is why i mentioned motor mounts. Dieseling could be a few things such as your timing being to advanced, or carbon build up on a piston or two. Carb not adjusted right (carb throttle plates open too wide, idle speed screw not adjusted right), running cheap gas in a high SCR motor can be the case to for it too. Pinging could be a few things too such as again the gas you are using, motor not getting cooled down like it should, carb ims not adjusted right, spark timing. What is the history on this motor, have you done some work to it recently, did this just start happening?
Old 07-02-2016, 11:13 AM
OldTech's Avatar
Does it have the electronics on it? or have you changed it over to carbs?
Old 07-02-2016, 08:58 PM
I've done very little with this motor and this issue just started happening. Since I've changed the oil, plugs and wires. My mechanic thought it had something to do with the timing, when in gear and at full stop it's pinging so hard it sounds like a diesel and shakes and rattles. Same with slow reverse. Driving slow or with speed it's just fine. He thought the timing chain may have finally stretched far enough that it's throwing off the timing settings. It's got over 210K on it so I'm just wondering what the next step should be.
Thanks for you thoughts.
Old 07-02-2016, 09:01 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Check the flexplate for cracks.
Old 07-02-2016, 09:24 PM
How do you check the flexplate?
Old 07-03-2016, 12:31 AM
Guest
Location: in the land of Trolls at least till the san andreas releases the big one
take the cover off the bottom of the bellhousing..
rap the flex plate with a hammer.. does it buzz... it might be broken..
you might want to spend the extra time with extreme care and proper sized tools and undo the 3 torque converter bolts.. push the converter back slightly away from the flex plate.. rap the flex plate with a hammer again it will make an odd sound if its broken..
you should be able to inspect more of it with a really bright flashlight now..
please use extreme care to reinstall the torque converter bolts. that you get 2 or the 3 installed without fully tightening them.. leaving them like 1 turn loose.. so you have some chance in heck of getting the third one in.. you can tighten the third one completely.. then tighten the other two..
that is how i inspect flex plates without removing the transmission. .
pinging, timing
Chevy 355 Initial Timing and Total Advance Timing bwhit071 Engine 11 07-15-2015 11:51 PM
Setting timing with a dial in type timing lite ? f/bird Engine 4 08-12-2013 07:21 AM
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
