Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing curve recommendation
Old 06-24-2009, 09:21 PM
blue54's Avatar
blue54 blue54 is offline
I agree with Colbalt327. That is a good initial curve. When you are done I would start the mech about 250 rpm above idle and depending on rear gear finish the mech just below cruise rpm. 12 to 14 initial with 34 to 36 total works well when no vac advance is used. If you are going to use vac advance go for 6 in the vac advance and 16 mech. I would run the vacuum on a ported source.
