The tool I'll only need once - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-02-2019, 06:47 AM
fat tire's Avatar
fat tire
I have a pushrod that I flattened on one end to insert in the pump.
with the engine out I use a regular drill, engine in I use an angle drill. worked for me for years
  #17 (permalink)
Old 05-02-2019, 06:50 AM
55 Tony's Avatar
But what about priming the valve train?
And as for the angle drill, I have one but my batteries are with my other tools at my girlfriends house. I just remembered I also have an angle adapter tool I never used. Could have used that even with other drills I have around here. Anyway it's done. May run today but a Dr appointment in the middle of the day 45 minutes away really screws me up. I better get out to the garage after this next cup of coffee.
Young enough to learn ... too old to remember.
  #18 (permalink)
Old 12-24-2019, 12:55 AM
Originally Posted by 64nailhead View Post
I have an old dizzy with only the shaft and I ground the top end to a 6 sided ordeal so my cordless drill grabs it easier.
I spend time on other forums. Over the years, I've lost track of the number of folks who post about burning-up 3/8 drills, especially cordless.
You're NUTS to use a cordless or 3/8 drill to turn an oil pump priming tool. The tool is spinning an oil pump that is geared to turn at 1/2 crankshaft speed. The engine develops plenty of pressure at cranking RPM--probably under 200 rpm.
You can prime just fine spinning the pump 60--80 RPM. About one turn per second. The oil is cold and thick, so it doesn't flow all that well.
And then someone puts a low-torque drill that's likely geared to spin 2000 rpm, but with little torque onto the end of the priming tool. Of course the drill burns up.
AT LEAST use a 1/2" drill, geared for 500 rpm, and four times the torque.
Better still, turn the pump BY HAND. For Chevy and Pontiac, take an old Points distributor, grind the teeth off the distributor gear. Thread a long machine screw into the top where the rotor used to screw on, and if you wanna be fancy, use a few inches of brake tubing over the threads of the machine screw as a handle. Works on any engine with a SUBMERGED oil pump driven by the distributor. (You may need a drill motor for Buick, Cadillac, Mopar B and RB, etc, where the oil pump is above the level of the oil, and must suck mightily to prime.) Oldsmobile is even easier--use a 5/16 socket to grab the oil pump driveshaft, and spin it with an extension on a ratchet or speeder handle. Ford with the hex driveshaft is probably similar.
What about it? Priming the oil system takes less than one minute. The ONLY thing you're trying to accomplish is filling the oil pump, oil filter, and main oil galleries with oil. The galleries will begin to drain immediately after the priming has stopped.
Some guys make a career out of "priming" the pump, turn the crankshaft, prime some more, turn the crankshaft, prime some more...all in the hope of squirting oil over the fenders from the rocker arms. I've seen posts where guys spend HOURS dicking with the oil pump priming tool. THIS IS CRAZY.
Every moving part in a new engine should be coated in assembly lube. "Priming" doesn't lubricate anything--it just displaces air. And hydraulic lifters are notorious for needing to be bumped by the camshaft before they'll properly fill and pass oil up the pushrods.
"Over-priming" to get oil at the rockers is another reason drills burn up.
Priming is DONE when you see oil pressure on the gauge. Shove in the distributor, and fire that mother up.
With a submerged oil pump, "priming" the oil system is MOSTLY just a "feel-good" deal. It really doesn't do anything useful, because even without priming, the oil system will fill within five seconds of the engine starting and running. In the meantime, all the parts are sliding on the assembly lube, no harm done.
  #19 (permalink)
Old 12-24-2019, 06:30 AM
chasracer's Avatar
True Hotrodder
I have learned around here that it's best to do what makes you comfortable. And if cranking the engine over a 1/4 turn, then hitting the primer does it for you then so be it. It doesn't hurt a thing (other than a drill motor here and there). For a long time I never primed anything, just coated everything with a mix of 50/50 oil and STP except piston rings - they just got oil. Now I prime them before first fire and prime with the starter if the engine has been sitting any length of time. Does it help? Maybe, maybe not- beats me but it makes me comfortable.
And yep, I have the old distributor version but I can see where on some installs that might be really tight with a drill motor attached.
  #20 (permalink)
Old 12-24-2019, 08:22 AM
55 Tony's Avatar
Since I'm borderline with spring pressures on only roller tipped rockers, I like to see oil coming out of the pushrods before starting it. They run hot enough with oil, don't want to see them run dry. That's for this build anyway, someday things may change.
Best quality hand tools? Are Snap On, Mac, Matco worth the extra $$? CometCyclone Garage - Tools 24 09-29-2014 04:52 PM
WATCH OUT buying cheap tools! MARTINSR Garage - Tools 101 12-12-2013 09:57 AM
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-19-2010 12:19 AM
Tool review on everyday universal everything tool. :) MARTINSR Body - Exterior 4 08-09-2009 01:15 AM
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 08:24 PM
