The tool I'll only need once - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2019, 07:42 AM
55 Tony's Avatar
I've lost track of how many times I've rented an oil priming tool from the local parts stores. But every time I think I'll never need it again, besides, I can always get it again in a ten minute drive.
So I run out for one last night and they no longer rent or even sell them. The guy says because people don't return them which doesn't make sense since the purchase price is less than the rental deposit. Oh well, I'll go down the road to another store, no they don't have them anymore either. S0B.
Come home and buy one from Summit cheap but have to pay shipping, who's advertised same day shipping doesn't ship until the next day (yes I've complained about this before). So hopefully tomorrow I'll have my own to use once, then never need it again.
Young enough to learn ... too old to remember.
Old 04-30-2019, 09:10 AM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
Get an old distributor, knock the gear off of it, cut off the weights and Springs and you got yourself a primer.
Old 04-30-2019, 09:30 AM
Big Jim
Last journal entry: Project Nova: Tornado Survivor
My philosophy has always been - need a tool once borrow it; need it twice, buy it.
Old 04-30-2019, 12:38 PM
Autozone ? Just checked their site for Tool Loaner" tool showed up. You could just order this one https://www.ebay.com/itm/Big-Small-B...0AAOSwlZFau4D3
Old 04-30-2019, 02:53 PM
64nailhead's Avatar
Geesh, I thought the title was taken from my wife's description of me :-l
I'm with 49 Ford Coupe - I have an old dizzy with only the shaft and I ground the top end to a 6 sided ordeal so my cordless drill grabs it easier.
The Following User Says Thank You to 64nailhead For This Useful Post:
55 Tony (05-01-2019)
Old 04-30-2019, 08:18 PM
BigMo's Avatar
Amazon, get it in 2 days
Sent from my SM-G900V using Tapatalk
Old 05-01-2019, 06:04 AM
55 Tony's Avatar
The autozone here said they don't have them anymore, my first stop was an ORiely Auto which isn't as big as AutoZone. Maybe since it was almost closing time the fricken A hole manager at AutoZone just wanted to get rid of me. I feel compelled to report him to his authorities. He constantly badmouths the store he works at. Not manager material in my eyes. Not something I normally do, it's just that he is so bad that you can't help but hate him.
Old 05-01-2019, 06:10 AM
55 Tony's Avatar
After my Summit order I saw one at Amazon that I could get in two days free shipping. I didn't like it because the end for the drill to attach looked round and really narrow like it could break off easily. Although now that I think of it, that could be a good thing as I sometimes have a problem getting the drill to fit into the cowl area. So when I get MINE, I can customize it to how I want.
Old 05-01-2019, 06:15 AM
55 Tony's Avatar
I actually have an old one on the shelf that is already missing the gear. Problem is it's from a 56 chevy and someone told me they would really like to have it, still has the aluminum tag that wraps around it with it's part number (I think).
Old 05-01-2019, 07:37 AM
S10xGN's Avatar
Gotta love a turbo!
Here's my freebie "recycled" solution if you have an LS, or other engine with crank-mounted oil pump. Reject SBC oil pump, aluminum scrap "handle", tapped fitting in pump for hose, hose, and oil passage adapter. Add your oil to a handy bucket, plumb up the lines, and hit the pump shaft with a drill motor. Beats spending $200 for a pressurized container system, and you can store all the pieces in the bucket if there's a good fitting lid...
Russ
Old 05-01-2019, 12:55 PM
55 Tony's Avatar
Is the thought or meaning behind that, if you need it twice you will most likely need it more than twice?
UPS came a bit late today for my old regular driver, but the tool was still here around 1PM. But I'm busy with other things. I already got the lifters primed again by dropping an old distributor down the hole and cranking, but I'll still use it a while because I didn't fill the push rods with oil. 3/8 rods take a while. (the bottom end hadn't been apart)
Old 05-01-2019, 05:32 PM
Big Jim
Yes it is. Just the way it seems
Old 05-01-2019, 06:39 PM
Big Jim
To explain a little further, there used to be no place in my area to rent these tools. If you didn't have a tool you would need to borrow from someone. Therefore if you needed it a second time you would buy it. This way you wouldn't wear out your welcome.
The Following User Says Thank You to Gearhead Poppa For This Useful Post:
idrivejunk (05-02-2019)
Old 05-02-2019, 05:00 AM
55 Tony's Avatar
Well I got the tool, almost had to cut it short to get it into the cowl area. Put the tool in first then attached the drill, I had at least an 1/8" to spare. Got the pushrods full of oil.
Old 05-02-2019, 05:39 AM
fat tire's Avatar
fat tire
I have a pushrod that I flattened on one end to insert in the pump.
with the engine out I use a regular drill, engine in I use an angle drill. worked for me for years
Best quality hand tools? Are Snap On, Mac, Matco worth the extra $$? CometCyclone Garage - Tools 24 09-29-2014 03:52 PM
WATCH OUT buying cheap tools! MARTINSR Garage - Tools 101 12-12-2013 08:57 AM
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Tool review on everyday universal everything tool. :) MARTINSR Body - Exterior 4 08-09-2009 12:15 AM
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 07:24 PM
