Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tools And How To Use Them
Old 11-20-2005, 09:16 PM
lowROLLERchevy's Avatar
lowROLLERchevy lowROLLERchevy is offline
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans
Wiki Edits: 22
also add:
Sawzall: a tool thats supposedly used fro cutting material. but more often then not its used to re-injur the wrist you sprained last week while tripping over your extension cord, can also be used for managing to punch yourself in the chest while under the car
Lathe: first tool used to take an oversized bolt and turn it into an undersized bolt
Tap & Die set: Tap, see drill bit reference in the EZ OUT section. Die: 2nd step used on the bolt mentioned in the lathe definition, DAMMIT TOOL is step 3, after retuning to the car to realize you made the bolt 1 size to small
