Trick with 4 Post Lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2018, 03:39 PM
jaw22w's Avatar
I recently purchased a 4 post lift. I agonized over a 4 post or 2 post lift. I wanted to be able to get the wheels off with the car on the lift. I came up with this. See pics. It is made from the jacking beam that came with the lift. I hole sawed (2) 1.5" holes 24" on center. Then welded 1.5" x .095" x 6" tube in the holes. I used 1.25" all thread with heavy nuts and welded 4" of 2"x2" angle to the top, V down. The all thread is long enough to be sticking out the bottom of the lift when the car is at ride height and the jack stands are against the axles. I actually made another jacking beam from a piece of 6" channel, so I had one front and rear.
I drive the car on the lift. Raise it a foot or so. Place the jacking beam and stands under the axles. Lower the lift and the stands catch the car and allow the ramps to drop out from under the car. Then adjust the nuts down on the all thread. Raise the lift back up and the wheels are clear of the ramp, supported on the stands. I liked this trick so well I made 2 more jacking beams with supports at different centers so I could support the frame from the lift also, for suspension work.
Both my cars are straight axle front and rear, but this trick could probably be adapted to A arm suspension. It takes me longer to type it than it does to do it.
I thought this was pretty neat. Don't know if it's has been done before, just thought I would share.
ID:	396810   Click image for larger version
ID:	396818   Click image for larger version
Old 01-01-2018, 04:18 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I just might steal your idea..
Sam
Old 01-01-2018, 05:12 PM
jaw22w's Avatar
Sam
Have at it. You're welcome to it. That's why i posted it. It really makes the lift way more useful. I think I am even going to use it to pull motors. Raise the car on the lift. Hook the motor to the ceiling and lower the car out from under it.
Oh! by the way. The plumbbobs have nothing to do with it. I am doing an alignment.
Old 01-02-2018, 06:40 PM
ProStreetRob's Avatar
RedLine Stage 4 ZL1 650rwhp
I use to spend a lot of time with my fun mobiles on a friends 4 post. Wish I would have thought about this back then, I've done some pretty stupid stuff getting it up in the air off the lift to remove the wheels
Great Idea
Old 01-03-2018, 06:26 PM
blwn31's Avatar
Very nice mod!
Keith
Old 02-04-2018, 01:11 PM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Hey, thats pretty dam cool man.
That would be great at changing ball joints and springs.
Old 02-04-2018, 07:09 PM
Bamamav's Avatar
I bleed FORD blue!
Neat idea! Now if I just had a lift I'd copy the idea.
4 post lift f/bird Garage - Tools 1 07-08-2012 09:43 PM
matrix lift trailers, mobile four post lift and trailer 58chevapache Garage - Tools 7 03-02-2012 11:14 AM
4 post lift help biscuitville Garage - Tools 3 07-05-2009 08:19 PM
2 Post lift Dreadlord Garage - Tools 3 03-28-2004 04:22 PM
4 post lift Dreadlord Garage - Tools 5 03-17-2004 12:52 PM
