triumph stag engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 06-20-2004, 06:44 AM
I have recently bought a 1973 Stag and want to swap engines. Anyone with experience with this car please share your thoughts. Thanks, Dale
Quick reply to this message
Old 06-21-2004, 09:11 AM
Last journal entry: More propane stuff
What engine do you plan on swapping with. I believe that the old buick v8 that triumph used in the tr8 would work. I know that that engine was modified by land rover and used in the range rovers. I remember hearing that the 3.8(tr8) would bolt up, but I am not sure. Your local triumph club should be able to help.
If it was me I would use a ford v8 ( thier narrower than a chevy and easier to find than the triumph 3.8).
Good luck
John
Old 06-21-2004, 10:38 AM
A friend of mine had one of those things and itīs main problem was warped heads, on the original motor.In the end he did a quick sell as the bills were piling up so fast. Then he got a phone call from Italy, thatīs how far it got, asking why the car was steaming and stationary.
Take a look here http://www.hurleyrotary.com/tristag.aspx
Old 06-27-2004, 04:04 AM
I am aware of the problems with the original engine and the fact that the closest replacement would be the Buick 215 v-8. These are scarce and do not give much improvement in performance. I have a Lincoln Mk VII with the 5.0 HO engine as a donor and would like to use it. I have found a site that gives the weight of the stag engine as 447 lbs. and the 5.0 ford as 460 lbs, so that seems to be a good fit. Also found one site that showed a stag with the 5.0 (95 Mustang) installed, but it did not give any contact info for the builder. So, any leads or further advice would be welcome. Thanks, Dale.
Old 06-27-2004, 09:56 AM
Tim240Z's Avatar
[flame suit on]
Have you considered any of the japanese engines? A rotory, or Sr20 or something along those lines give near V8 power levels in very small packages.....
Tim
Old 06-27-2004, 07:15 PM
Mostly familiar with British or US iron. Would consider Japanese engine, though. Any thoughts on which rotory would be the most bang for the weight, and what cars ran a sr20 engine. Thanks, Dale.
Old 11-03-2004, 11:16 AM
1an 1an is offline
Interesting website
I have found a website you may be interested in http://www.stag1.co.uk dunno weather u have already seen it or not but it could be helpful...
Old 11-03-2004, 05:35 PM
Talking Stag engine swap site
Hello, and thanks for th eweb site! Looks great. I have just bought a stag that is complete with the chevy 350 drivetrain to drive while I try to figure out what I really want to do with my project car. I have a Ford 4.6 mod 32 valve engine and trans now from a Lincoln Mk VIII and wouod like to see that in the Satg some day! For now I'm still looking at alternatives, and have found some olks put Corvette IRS rear ends in with the engine swap to handle the extra power. Also found one fellow in Texas who did a Mustabg II front cross member, susspension to relace the stock front end and give some more clearance to the engine bay.
Thanks for the reply, Dale.
Old 11-03-2004, 06:39 PM
dmc12mk3's Avatar
Last journal entry: Fixed some leaks
http://www.britishv8.org
All kinds of goodness there. Not just v8 stuff, should help you out some.
Old 05-28-2008, 05:20 PM
Mr Suntail
I have a Stag and its fitted with a 3.5 L rover motor, and a Toyota Supra 5 speed Gear box. this is not too uncommon, and In Australia rover v8's are not to uncommon. the Disadvantage however is the pound to AU dollar conversion if you want to get bits from the UK.
I am very happy with this conversion and to suggest that it doesnt improve performance is like saying "i can run as fast as a car, if its off a cliff"
It goes really well and i clocked a 14.6 on the quater mile at the local Drag track.
i use the original diff sitll, but look into the Datsun rear end conversion for the A shafts. the Datsun Z rear has bearings the stag does not. they fit on real easy, and its a good idea if you are giving it more power. the stag rear would Grap under power in corners and throw you off the road if you have too much grunt and manage to twist it a bit, where the datsun ones are able to twist thanks to the bearings.
If you were going a Jap motor, id use the 4.0 litre V8 out of the toyota/lexus. you can get a kit to attatch a supra manual to it, they are really cheap and and very solid. good power and a six bolt bottom end means very strong, thrashable engine.
The TR8 used the Rover v8 3.5 L which is also found in 4wd and rover sd1's.
make sure its a P6 engine not a P5. the P5 was not as good.
make sure you research the setup on the carbie, and exhaust because the power can (and is proven on many a rover website) be taken from 135hp to 192 hp just by using a holley and offenhouser (i cant spell) and sports exhaust, cause from factory they are choked up big time. hope this helps and if you want me to send photos of mine email me. by the way, its a tight fit. i had to take off the Mechanical fan to fit the radiator in and i have a full time thermo going pretty much all the time.
mr Suntail
Old 05-28-2008, 05:52 PM
Old(s) Fart
Last wiki edit: Wheelbase database
The Buick engines are quite plentiful if you look under the hoods of most 80s and 90s Range Rovers. EFI and displacements up to 4.6 liters.
Old 07-11-2016, 03:18 AM
Hello...just saw your post...I've recently bought a Stag with the Rover 3.5L engine and Supra 5 speed box. I'n in Nowra. Wouldn't mind a chat at some stage just to compare notes.
Old 07-11-2016, 05:50 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
swagman: 12 year old thread. Please read dates.
Some of those members have not logged in for 8 years.
Closed Thread
