Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Troubleshooting my 1950 Studebaker Champion
Old 09-29-2008, 01:10 PM
WagonMan WagonMan is offline
Last journal entry: 29 Ford Tudor
If the above check out OK, pull the distributor cap and check the point gap. The tab on the points may be worn down so as not to open the points correctly any more. Could also be a failing condensor in with the points.
Charles
