Tubing-to-hose barb fitting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2015, 05:57 PM
On my 400 turbo tranny there is a supply and return line that runs to a cooler. The 3/8 OD line has been cut on each to transition to the 3/8 I>D> line that connects to the cooler. The lines at the cooler connect to barbed fittings and seal nicely, problem is the hose, at the other end just slips over the cut steel tubing and even with two clamps still leaks.
Question is; What is the proper way to make this transition connection? Is there a flare-to-barbed fitting? or a compression-to-barbed fitting? What is the correct way to do this to insure a no leak connection?
Capt'n Jim
Old 08-05-2015, 06:05 PM
Roger Mabry's Avatar
There are both types of fittings
If you can flare the tubing, you can use that type... if not there are compression to barb fittings.
I have a great shop that I get these fittings from.. maybe there is a hydraulic hose shop near you?
Or check out any major speed shop on line...
Old 08-05-2015, 09:14 PM
Do a partial double flare, just the first step to swell the end of the tube to make it seal.
Old 08-06-2015, 10:42 AM
Old(s) Fart
Last wiki edit: Wheelbase database
Ideally you want a bead on the end of the tube, but those tools are expensive. The next best choice is an ISO bubble flare, as it is easier to insert into the hose than a normal flare.
Old 08-07-2015, 05:49 AM
Thanks for the suggestions guys, went with the compression fitting and then barbed adapter and it worked out well. A little more bulky than straight off the tube but it works and does not leak! It is great having you guys to bounce problems off the wall with.
Capt'n Jim
AC accumulator with barb fitting question! supercab78 Hotrodding Basics 4 04-04-2011 07:49 PM
Saddle cuts for fitting and welding tubing together. cboy General Rodding Tech 4 01-30-2010 03:13 PM
same brake hose fitting? maverick3656 Suspension - Brakes - Steering 5 11-01-2009 02:47 PM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
does anyone know of a 11/32 three way barb T fitting? Berliner Bel Air Engine 0 09-18-2004 04:54 PM
