Turbine paint sprayers - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 05-05-2019, 07:03 AM
Pats55's Avatar
The last few cars I painted I use the CX 9 turbine and it worked fairly well. I see a lot of threads where there's problems with fish eyes using the compressor. Curious to know other opinions.
Old 05-05-2019, 10:29 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I tried one and it worked just OK. Not good enough to recommend one for painting cars. Just my opinion and maybe there are some turbines of better quality than the one I tried..
Sam
Old 05-05-2019, 11:28 AM
Pats55's Avatar
Hello Sam I bought this outfit 12 years ago it seemed to be okay.It was a Crox CX9 My compressor and system itself wasn't all that great so I figured it turbine would eliminate at least the fish eyes. Some of these turbines and guns can be quite expensive. Mine was middle-of-the-road with a larger tip For my coatings. I was wondering if the body shops were using these in lieu of a compressor for paint.
Old 05-12-2019, 04:07 PM
I have an accuspray turbine with pressure pot, and two guns to use with it. Cost about $1k used for the whole get-up. I don't use anything else anymore. And it works better than anything I've used before.
Well I do use an airbrush from time to time. But for all my paint work I use the Accuspray. For primer, I have a gravity feed 2mm gun that uses air compressor, I also use the develbiss air filtration system for breathable air from the compressor. (Best $ spent)
Old 05-12-2019, 05:07 PM
Pats55's Avatar
Thanks. that's good to know. I don't think I'll be doing anymore painting of the entire cars. If I were younger I would invest in an accu spray system That CX 9 I bought worked fairly well and it wasn't that expensive. It would be a good piece of equipment for somebody starting out.
Old 05-12-2019, 05:37 PM
The Croix turbine is also a good unit. The turbine system is not just for all overs, but works very well on panel repair, and spot jobs as well. One of the guns I have, has a quart cup, that is pressurized by bleed air from the head. a 0.9mm fluid tip, and #7 air nozzle, does just fine, with base, and high solids clear as well.
I got the pressure pot unit because that's how it was set up at the pawn shop where I got it. I used the PP to paint airplanes. Lots of surface area to cover, and don't want to re-load in mid pass.
Oh, and the turbine is extremely portable too!
Old 05-12-2019, 05:53 PM
Pats55's Avatar
I love the idea that they're so portable. I couldn't imagine me painting an airplane.. Every time I sprayed Centauri I would always wind up with a dull spot where the overspray got it. I tried all different techniques but in the end it was cut and buff. This is too much work for man my age. It's nice to watch all the talent on this forum. I graduated from the Academy of" You didn't have enough time to do it right the 1st time, but you had time to do it over.
Color match problem with the paint jobber HotRodMan Paint 29 05-05-2014 10:49 AM
It looks like someone sprinkled sand in my paint job! HotRodMan Body - Exterior 23 04-03-2013 12:05 AM
Hood and front fenders, remove for paint? Mach1460 Body - Exterior 5 06-30-2012 11:04 AM
hvlp paint turbine 34coupe Body - Exterior 6 06-20-2004 04:55 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
