Urethane paint tips? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 05-30-2016, 07:28 PM
-Hi guys, I am a hobbyist with a little experience spraying enamel paints. I am thinking about giving a urethane based paint a try.
-I am thinking about in general if you have a Urethane based paint and can't get your hands on the reducer or hardener (that's recommended) do to time shortage is it possible to use another brand hardener or reducer?
-I am thinking of using SPI single stage urethane black or Urekem single stage black from the coating store. Both of these would have to be ordered. It would be nice to know if there was a reducer hardener I could pick up locally at an autoparts store if short on time???? (For example if I spilled a bottle on accident) Any thoughts experiences with urethane in this situation?
-Also for scratches chip touch up will the urethane paint dry without using the hardener?
THanks,
Brandon
Old 05-30-2016, 07:37 PM
idrivejunk's Avatar
Grand Prix user
Last journal entry: Last look
Reducer- probably yes, in a pinch. Generic products are available. I would draw the line at hardener, and stick with the right product. Yes, single stage touch ups will dry eventually but never cure.
Better call the tech line
Old 05-30-2016, 08:19 PM
TucsonJay's Avatar
I would make sure you have solid advise from the manufacturer.
There are a number of generic urethane REDUCERS, which I have used with no problem. Just talk to a nearby local paint store for advise.
BUT! ....
If you experiment with the HARDENER... and it is NOT right for the paint.... it will not harden up... and you will have to strip all of the paint off and do it completely over!!!
Wouldn't it be better to wait for the right stuff???
Old 06-01-2016, 05:00 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
since your going to order it why not just order it from the source? SPI will ship for free and you'll get the proper hardner/reducer
Old 06-02-2016, 11:03 AM
Yes deadbodyman, if I do go to order from the source I will get it from them. But right now i just have a small sample to play with and was wondering if Urethanes can be reduced by say acetone for example. But I will be calling them eventually just wanted to talk to some people lwith experience first. Thanks
Old 06-02-2016, 01:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
and get the proper reducer while you are at it.. Main thing on urethane is gun adjustment so it lays out wet and slick. you do not want to sand if you do not have to..
Sam
Old 06-02-2016, 01:56 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
how to make jelly in 1 simple step ......
The Following User Says Thank You to shine For This Useful Post:
John long (06-02-2016)
help! eastwood urethane flatz paint JazPro Body - Exterior 0 10-26-2010 02:46 PM
Sanding SS urethane paint before recoat ka24deroadster Body - Exterior 9 07-01-2009 06:41 PM
one step urethane paint yragat Body - Exterior 3 04-17-2009 11:34 AM
Basic paint questions (urethane) -Havoc- Body - Exterior 3 05-20-2008 08:34 AM
Acrylic Lacquer over Urethane paint. northiam Body - Exterior 10 03-17-2008 08:21 AM
