V-belt to surpentine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2019, 07:48 AM
Hello, I have a 75ish 350 and I have pulled a surpentine system off a 92 4.3 engine. I’m pretty aware of everything except whether or not the harmonic pulley alligning to the v8 after it is installed or do I need to get the harmonic balancer off the 4.3 too or is that even possible to work on a V8?
Old 02-23-2019, 10:44 AM
Use the balancer you have, all SBC and 4.3 locate the pulley face the same distance from the block, at least until about MY 2000.
Old 02-23-2019, 11:40 AM
Okay thanks a bunch. Hopefully it all goes together nicely. I’ve wore my butt o;; trying to polish up those machined aluminum brackets.
Old 02-24-2019, 06:49 AM
cozwurth's Avatar
Last journal entry: Vinyl top carnage...
You will need to replace your water pump too, if you didn't do that already as part of your conversion. The serpentine pump is reverse rotation.
Old 02-24-2019, 01:48 PM
Yeah, I took everything off of a van my step dad has. He had just replaced the water pump before he stopped driving it so I’m just gonna use that one. The truck I’m building is a weekender so if it goes out it’s no big deal and easy to fix with this surpentine system.
The Following User Says Thank You to swaggoner For This Useful Post:
cozwurth (02-24-2019)
Old 02-25-2019, 06:03 AM
silver74vette's Avatar
Would love to see a picture once you get the brackets polished!
Old 02-26-2019, 05:31 AM
I have to go over them with the 3000 grit and I believe that will finish them up. When I started they were pretty much black from the grease 😂... I have encountered a problem, I have flowtech heads on it, apparently the spacing of the bolts do not match the stock gm so on the alternator bracket only 2 of the 3 bolts match up. It’s secure but I’ve had bolts to break due to them not being secure enough. Any suggestions?? Here’s a pic of my heads also
ID:	440811   Click image for larger version
ID:	440813   Click image for larger version
Old 02-26-2019, 10:36 AM
I would be more worried about the heads stripping out than the bolts breaking. How much clearance do you have behind the last bolt? Can you possibly make a 1/4 inch aluminum bracket and cut 1/4 inch off the bracket and countersink it on opposite sides to mount it flush and offset the mounting holes?
I hope that makes sense. Think of a countersunk bolt holding the bracket into the head, and then another countersunk bolt facing the opposite way that you can put a nut on the front of the bracket to secure.
Old 02-26-2019, 11:53 AM
Silver74vette, that does make sense. When I get off work tomorrow I’ll take a look and see if that will work. Right now there’s no clearance. Pretty much the right side of the bracket dead centers the hole on the head that will not match up.
Old 02-28-2019, 08:29 AM
Okay, so my bracket has a metal piece that attaches between the bracket and the head. I welding solid to make up for the rest of what would be needed to drill a hole into that metal bracket so I can secure it to the head. I did that and secured that bolt and bracket first to the head then attached the actual full bracket to the head, if this makes any sense. It seems to be good and secure. I welded more but didn’t take any further pictures.
ID:	440867   Click image for larger version
ID:	440869   Click image for larger version
Old 02-28-2019, 10:48 AM
I put on these kits on recently and the instructions mention an issue with that bolt.
Look at page 5 of the instructions.
https://www.chevrolet.com/content/da...7-19369258.pdf
Old 02-28-2019, 05:46 PM
My truck has the flotek 185cc heads, it's an 88 k1500. I had the same issue with the one bolt not lining up, plus the alternator on the passenger side had the power stud hitting my valve covers. I traded brackets with my dad who had a 91 k1500 that had the alt on the driver side and ac compressor on the passenger side. Everything lined right up then, may be something to check out for you.
The Following User Says Thank You to Dfish1247 For This Useful Post:
lmsport (03-01-2019)
HOW TIGHT DOES A Grilmer Belt Drive BELT SUPPOSE TO BE the82elco Engine 7 12-23-2012 01:41 PM
serpentine belt & water pump belt coldfreshwater Engine 3 12-19-2012 06:03 AM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 09:01 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 06:56 PM
Shoulder belt install question. slider in wa Body - Exterior 5 01-22-2003 06:14 AM
