Valve spring height, help with my math. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2014, 06:41 PM
Richiehd's Avatar
JS-70
I have a set of World Sportsman iron heads for this 327 Im building. I have some Scorpion intakes and exhausts. .200 longer. Valve spring specs [email protected] installed height. I measure 2.005 with no shims. Seems like I need .130 spring shims. That doesn't seem right. Even with -.50 keepers Im still. 080 out.Am I measureing wrong? or do I have wrong springs?
Old 11-25-2014, 07:40 PM
vinniekq2's Avatar
areyou measuring to top of retainer or spring?
Old 11-25-2014, 07:52 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Probably not, you just have some really long valves. Would +0.100" not have worked?
Old 11-25-2014, 08:10 PM
ericnova72's Avatar
More for Less Racer
Like the Inspector pointed out, should have used just +.100" longer valves for those heads.
-.050" keepers and .080" shim is the best you are going to be able to do without hunting through several dozen different spring retainer manufacturers catalogs, to see if they have anything that installs shorter on the valvestem.
Old 11-26-2014, 05:25 AM
Richiehd's Avatar
JS-70
Actually they are .150 Scorpions. Yes measuring to top of spring, inside retainer.
Old 11-26-2014, 03:57 PM
Another option that may help is a spring locator or cup. It depends on the size of your valve stem guide/boss for location on head as well as spring pocket/spring OD. Comp has them for both spring ID locators and spring OD cups. They all look to be .060" thick. May help to keep from having a slopy stack of shims?
I know they are recommended for aluminum heads, but not sure about iron. Don't know why not? I printed a page out of the old pdf catalog I have and scanned it for a jpeg. Hope you can read if your interested. It looks ok if you increase your zoom settings.
FWIW
Good luck!
ssmonty
ID:	189289   Click image for larger version
ID:	189297   Click image for larger version
Name:	Comp spring locators and cups 001.jpg
The Following 2 Users Say Thank You to ssmonty For This Useful Post:
ericnova72 (11-26-2014), Richiehd (11-26-2014)
Old 11-26-2014, 08:47 PM
ericnova72's Avatar
More for Less Racer
You can certainly use a cup on an iron head, just as long as the spring pocket is machined large enough on the O.D. for the cup to fit down in the pocket.
If you need to shim plus the cup, the shim has to be put under the cup(or the locator, if you choose to use those instead of cups).
I.D. of either the cup or the locator has to be nearly the same as the valveguide O.D., to prevent too much "walking" around under the spring
Old 11-27-2014, 05:37 AM
Richiehd's Avatar
JS-70
Thanks for all the input. I found some locaters I think will work along with -.050 locks from Comp. Happy Thanksgiving to all my Hotrodder.com friends!
Valve spring height and spring ? eric866121 Engine 5 10-11-2014 05:39 PM
Using a valve spring height mic v8hed Engine 5 01-22-2014 09:46 AM
Valve Spring installed height 70bird Engine 2 04-15-2007 11:44 AM
Valve spring installed height 72 Chevy Nova Engine 11 02-13-2007 12:16 PM
valve spring installed height? Kramer Engine 5 05-16-2003 04:36 PM
