Variable speed fan? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2014, 10:31 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Variable speed fan?
I have a question for all of you electrical guru's on here. I have a blower fan on my home wood stove. The one on there now (well was on there) is now locked up/ shorted out/ something, it's bad and I'm going to replace it. It was set up originally as a single speed, plug and play type deal. What I am considering is a variable speed switch of sorts so I could slow it down, when I don't need full blast from the heater. What I am wondering is this, can I use a light dimmer switch to reduce the voltage to it and make it variable speed? Or do I need some other kind of switch? OR should I leave well enough alone and turn it on and off as needed? Sorry if this is a ignorant question, but I know enough about electricity to wire in a switch or outlet, other wise I am voltage illiterate......... It is a 1/20 HP dayton 115 VAC motor if that makes any difference, Thanks in advance for any advice you can offer.
Kelly
Old 11-10-2014, 10:44 PM
Or would this work?
Shop Lutron Rotary 1.5-Amp 300-Watt White/Ivory Rotary Fan Control at Lowes.com
Kelly
Old 11-11-2014, 05:07 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
I dont think a dimmer would be heavy enough...but I am no electrical genius either.
Moving this to the Garage forum, more should see it there
The Following User Says Thank You to poncho62 For This Useful Post:
carolinacustoms (11-11-2014)
Old 11-11-2014, 05:47 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
fireplace fan
GFK-160B Time Controlled Fireplace Blower 180 CFM Fan Kit With Hi/MH/ML/Lo/OFF Speed Control
It's been a while since i read the directions on our fireplaces we are installing in our smaller retirement home. My wife does the research on what she wants, I just install. We have a few large wood stove - fireplace stores in this area.
Old 11-11-2014, 05:55 AM
johnnyg's Avatar
hold my beer and watch this!
No you can't. You could get a multi-speed motor. There is a variable speed motor assembly for furnaces, it is a DC motor with a controller. The one I priced for a customer last year was over $1000!! A few hundred more dollars he could've got a new furnace!! I sold him a 3 speed AC motor instead.
Old 11-11-2014, 06:27 AM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
The problem is light dimmers are not designed to carry that much current. You can however probably find a motor speed controller for short money on Ebay or similar
Something Like this
Router Variable Speed Controller Electric Motor AC Control Rheostat for Tools | eBay
Chet
Old 11-11-2014, 08:10 AM
1971BB427's Avatar
You can't use a dimmer switch for a motor. You need a motor rated switch, and it needs to be sized for the motor. There are numerous variable switches available to use on things like attic exhaust fans, etc. that will work and not fail quickly.
Fan switches (unlike dimmers) start on high, and then get slower as the switch progresses. The start on high is a big help in switch life, and motor life, and you'll need that feature. Here's a bunch on Amazon in both rotary, and slide styles.
http://www.amazon.com/s/?ie=UTF8&key...l_1b1kt0nxy2_p
Old 11-11-2014, 03:07 PM
johnnyg's Avatar
Amazon.com: fan control switch: Tools & Home Improvement
Those will not work for a blower motor.
Old 11-11-2014, 07:26 PM
1971BB427's Avatar
And might you tell me why they wont? I've only been a licensed electrician for 38 years, so I'm happy to learn from you.
As long as the switch is motor rated, for the correct voltage, phasing, and current draw, there shouldn't be an issue. A switch doesn't know what the motor is operating. His 1/20th HP motor should raw about 2.0 amps, which will come to 230 w. A motor rated speed control switch will need to accommodate a in rush current of about 3 times that amount, so if it's rated in watts, I'd go 600w., and if in amps, then large enough to handle the 2 a. load.
Old 11-11-2014, 08:10 PM
Thanks for all the help from everyone. The new motor should be here Monday, and I think I have found everything else locally to make it work out. Thanks again
Kelly
variable speed 4 1/2" angle grinder thirdmouse Garage - Tools 1 02-11-2010 04:38 PM
Variable Speed "V" Belt changer info acourtjester Garage - Tools 7 07-18-2009 10:46 AM
Variable speed for angle grinders useful? SteveU Garage - Tools 7 12-15-2008 05:50 PM
2 speed fan confusion wayneair Electrical 5 05-13-2006 03:28 PM
Need Electrical advice, variable speed motor wiring? 327amc Electrical 13 02-01-2006 01:28 PM
