vibrating or tumbler abrasive cleaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2015, 02:01 PM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
Anybody tried the HF small parts vibrating or tumble abrasive cleaner for small stuff like bolts I'm thinking about getting one if they work.
Old 01-31-2015, 02:09 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Dont know about the HF ones, but our machine shop at work has one...Does a super job on stuff
Old 02-01-2015, 07:06 AM
Wiki Edits: 11
Is it the viberating kind or the revolving tumbler type?
Old 02-01-2015, 07:15 AM
Banned
I have the h/f one , mother gave it to me a few years ago.. works fine..
I got the adbracive at tractor supply as it was much cheaper
Old 02-01-2015, 07:40 AM
Wiki Edits: 11
Black diamond abrasive ? I was thinking about using that too....
Old 02-01-2015, 08:09 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i have the middle sized vibratory one from eastwood
i use the green diamond abrasive in it.
i dont think it works very well on steel
i mostly use it to help in polish small alum parts
Old 02-01-2015, 08:18 AM
Banned
yup
Old 02-01-2015, 08:25 AM
& matts38chev
the good thing about them, is the fact that you can be something else, while it is working away in the corner
Old 02-01-2015, 08:42 AM
Banned
I load mine and turn it on, have it pluged into a timer, so it can run overnight.. run one hour, off to rest it, then on 30 minutes later, then off after an hour.. etc.. not that it can't go for hours on end.. I just think it's safer this way.. that chance over working it, while not in the garage to shut it down, if it gets overworked and try's to let the majic smoke out..
Old 02-01-2015, 12:18 PM
ogre's Avatar
the 'Duracell Project'
we have the big harbor fright vibratory for deburring plasma parts
get a timer dbm... you don't want to be in the same building when they run
Old 02-02-2015, 06:16 AM
Last journal entry: Still running strong
I'd degrease anything that goes in it. I use a home made one to polish brass that I reload. You can also dump out an save different kinds of abrasives. I use walnut shells with car wax mixed in to polish an walnut shells without wax to clean.
Old 02-02-2015, 07:25 AM
Wiki Edits: 11
Exactly what I was thinking I have better things to do with my time than cleaning nuts and bolts, even if it only takes 2 hrs by hand that equals 100.00 to clean bolts ,something like this will be very cost effective.
Old 02-04-2015, 07:43 AM
1971BB427's Avatar
Different media, for different materials. If you match the media to the material, they work great. There are also liquid additives that can be poured into your media and help the tumbler to polish better. I use a liquid media with walnut shell, or corn husk to polish aluminum and brass/copper.
Replace Ignition Key Lock Tumbler raglandk General Rodding Tech 4 11-12-2008 05:21 AM
Removing Ignition tumbler with no keys flyinv55 Hotrodding Basics 3 09-14-2008 12:24 AM
Question on changing tumbler or switch. rbnatkn Engine 4 06-24-2008 06:01 PM
Ignition key tumbler replacement Hammer350 General Rodding Tech 1 06-24-2008 05:56 AM
gm ignition tumbler jackflash Electrical 2 08-22-2005 06:00 PM
