volare in a 34 plymouth coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2004, 08:23 AM
Has anyone tried the volare on an early plymouth or does anyone have a better suggestion. thanks for any advise you have. I am returning to hotrodding after a short 30 year pause!
Old 12-14-2004, 12:39 PM
volare rear end
If the dimensions are similar in width , I would see no problem in it. I guess the big question is what engine your rear end was behind.
And what are you going to put in front of it now?
Old 12-14-2004, 03:44 PM
Volare clip
This clip has a pretty wide track,would not work well on a narrow car or truck. I have one under a 46Ford 1/2 ton, I may have to run negative offset wheels to make it look right. I had this same clip under another rod and it worked well. good luck
Old 12-14-2004, 05:38 PM
volare rear end
Ah, you are talking about a front frame stub. I was under the impression you was swapping out a rear end.
Old 12-15-2004, 12:59 PM
polare front clip in a 34 plymouth
Thanks for the replies to my foggy question. Can anyone give me the outer measurements for the polare clip - i wonder if it will fit between the 34 rails or if I have to splice them.
Old 12-15-2004, 01:58 PM
Volare clip
It should be wide enough,if not pretty close. Good idea to tack everthing and make sure it`s right before final weld.
