Warpage! what to do. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-16-2006, 05:16 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
No,
You want to grind them down CLOSE to flat, leaving, say .030-.060 (guessing) so that WHEN you Hammer & Dolly you aren't too thin. Remember, what you are doing is to Hammer the Welds flat (making the Metal thinner, so you are in fact "stretching" the Metal).
If you were to start Hammering before grinding you will end up with a mess. It's hard enough to get consistency with the welds ground down (with a good series of "spots"), you will have to be patient and watch how much you are hammering.
From the sounds of what has happened, I will venture a guess that you have "puckered" this panel because you had a bunch of blow-throughs, then you spotted them back, creating more heat (which equals more shrinkage) in a small area, making your problem more challenging. Put aside a bunch of time, as you will have to gauge how much you are stretching as you are hammering (on Dolly).
I have fought Panels like this before, so Hammer, check, feel, Hammer, check feel, and so on.
  #17 (permalink)
Old 10-16-2006, 08:07 PM
The bulges/puckers are at the corners of the patch panel. I had to stairstep the shape to avoid old lead fill areas. It makes sense because that is where there is the most concentration of welds (heat). I was real careful about heat but it did it anyway at the corners. I don't have faith in this hammering thing yet because I have never tried it. Seems weird right now. I hope it woks because I have to cut access holes and reach in with one of those long dollies. Never done dolly work either. do you just place dolly behind the weld and hit on dolly/weld? How hard of a hit are we talking? Megahard or tap or like nailing in a small nail or? Thanks very much for the advice 35window! I really need help right now. I don't feel good about the project/job I did. I am leaning to weld thin though. Using 20ga, hope it hammers well. The copper trick is the only way I would have fixed the burn thrus. Otherwise I was chasing holes around all day.
  #18 (permalink)
Old 10-16-2006, 08:39 PM
[email protected]
Keep in mind, when hammer and dollying, the harder you hit, either the quicker you will be done, or the more damage you will do. With little or no experience, you need to do it in small steps. That means small hits.
Aaron
  #19 (permalink)
Old 10-17-2006, 08:38 AM
35WINDOW's Avatar
I would recommend that you purchase one of the Video's that are available on the subject (Ron Covell, Ron Fournier, Wray Schelin)-I'm certain there are oithers, but you should understand the concept first, practice on some Sheetmetal to gain some skill, then attempt your panel (IMHO)-
  #20 (permalink)
Old 10-17-2006, 08:46 AM
Use a hammer on dolly to stretch the metal, use a hammer off dolly to bend the metal/change the height of an area. Another good tool to use is a hand held shotbag instead of a dolly when moving metal height. Grab yourself a scrap piece of sheetmetal and spend some time with both techniques to see for yourself how dolly placement and hammer force effects the sheetmetal. The shrinking disc is an awesome tool and if anyone doing bumpwork doesn't have one definately buy one or make one yourself. Bumping large flimsy panels like hoods and roofs and trying to shrink areas on such panels is almost impossible without the disc, a torch or unispotter used for shrinking can create a whole lot of damaged in the hands of the inexperiences. With the shrinking disc if you shrink too far simply hammer and dolly some stretch back into the area and proceed.
  #21 (permalink)
Old 10-17-2006, 11:00 AM
Shabby chic sheet metalshaper
Brian,
I just thought of something; have you tried putting more pressure on the metal when using your shrinking disc?
Bartamos,
Here is an aricle with links to several more on dent repair etc:
http://metalshapers.org/101/jkelly/index.html
Pratice on test panels before working on your pride and joy!
John
  #22 (permalink)
Old 10-17-2006, 12:09 PM
Originally Posted by John Kelly
Brian,
John
John, I'll give it a try, I though I was applying enough pressure. The only things I have been using it on lately are 2006-7 Toyotas and applying a lot of pressure to the center of the roof of a new Toyota Corolla isn't going to get you much other than a caved in roof.
I'll work on that though. I am using the monster 15 amp 5000 rpm grinder that weighs a ton. It is pretty hard NOT to apply a lot of pressure just from the weight of that thing.
  #23 (permalink)
Old 10-18-2006, 12:45 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Your wandering again!!!
I ordered one from John. I got a problem child hood with a cuple of high spots which are not accessable from underneith due to the bracing and my readhering the brace to the hood probbly didn't help matters. Some bigfoot mashed in the right center of the back edge hood skin and I got it worked back up with a stud gun but it needs leveling back down and the hammer/dolly just won't work due to no openings and I'm sure not cutting the brace.
Panel warpage help? Gearhead forever Body - Exterior 8 12-03-2005 06:02 PM
warpage Jzarczyn Body - Exterior 22 10-11-2004 07:47 AM
How to check rearend housing for warpage? shockers69 Transmission - Rearend 1 07-13-2004 12:11 AM
HELP weld warpage Lay'nFrame Body - Exterior 7 02-25-2003 11:00 PM
Correcting Weld Warpage? TurboS10 Body - Exterior 8 01-31-2003 06:47 PM
